Change of base formula, is this what hes talking about? logs
The discussion revolves around the change of base formula in logarithms, particularly in the context of a discrete math class. Participants are exploring how to convert logarithms from one base to another without the use of calculators, focusing on examples involving base 3 and base 2.
  • Participants discuss the change of base formula and its application, questioning whether converting logs to base 10 is appropriate. There are inquiries about the meaning of the base in the formula and how to evaluate logs without calculators. Some participants suggest using base 2 or base e for conversions.
The discussion is active, with participants sharing insights and clarifying concepts related to the change of base formula. There is recognition of the challenges posed by the exam format, and some participants are creating their own examples to aid understanding. No explicit consensus has been reached on the best approach, but various strategies are being explored.
Participants note that calculators and tables are not allowed during evaluations, which influences their approach to solving logarithmic problems. There is also mention of the exam format differing from the multiple-choice examples discussed.
mr_coffee
Hello everyone.
This is for a discrete math class, and he said you must know the change of base formula, so if you have everything in log base 3, you can figure out what it is in log base 2 as an example.
But I'm looking up the examples on the interenet and they all seem to convert whatever log they have to log base 10 and evaluate from there. Is this also what he would be talking about? No calculators are allowed to evaluate the logs.
Here is the change of base formula:
http://www.icoachmath.com/SiteMap/images/clip_image012_001.gif
and here is the example I'm looking at:
http://www.icoachmath.com/SiteMap/images/clip_image014_002.gif Okay i see that x = 4, and z = 8, but what is the base y? is the base y the new base you are trying to convert the orginal base into? FOr this example, you are given a base 4 log, and your trying to convert it to a log of base 2 and evaluate the answer I'm assuming right?
how did they end up with 3/2 though?
EDIT: I figured out how they got 3/2, i forgot about the other form of logs, 2^3 = 8, and 2^2 = 4.
Another example:
Use the change of base formula to evaluate
http://www.icoachmath.com/SiteMap/images/clip_image002_084.gif Choices:
A. 4.56
B. 4.86
C. 0.21
D. 5.16
Correct Answer: B
Solution:
Step 1:http://www.icoachmath.com/SiteMap/images/clip_image002_085.gif
Also is it up to you what base you convert it too? I see they used base 10 but there was no base 10 in the orginal problem.
how did they get: 2.43 from log_10(29)/log_10(4) ?I know this is algebra stuff but its been awhile :blushing:
Thanks~
mr_coffee said:
Hello everyone.
Another example:
Choices:
A. 4.56
B. 4.86
C. 0.21
D. 5.16
Correct Answer: B
Solution:
Thanks~
They choose 10 because most calculators have a log base 10 button, but not a log base 2 button (I'm none have this).
Another choice is base e, which is what I would use personally. All scientific calculators have a button for log base e, and it is usually understood as ln.
That's the real reason.
Sure, you can use base 5, but now what? You still can't solve it.
Note: I saw that you can't use calculators, then I'm assuming you are allowed tables or something to figure it out.
Oh, since it is multiple choice, you can just check each answer by brute force. Not that hard.
we won't be allowed to use tables or calculators so maybe i'll switch everytyhing to base 2?
No, just solve by brute force. I can hardly call it force though.
You have multiple choices, so you can simply check which is correct one by one.
The solution is probably just to prove that it is the solution.
On the exam it won't be multiple choice though, this was an example i found on the internet to help me study. His exams usually arn't multiple choice but maybe i can hope hah.
Oh!
I see it now.
The one online isn't a good example though because it doesn't have a "nice" solution to it.
The one your teacher gave does have a nice solution. Notice how he appropriately chose 2 as the base?
Here, I made a "nice" solution question for you...
Solve the following without calculator or tables:
[tex]log_{243}27[/tex]
i got log_3(27)/log_3(243) = 3/5
look good?
BRAVO!
Now, from that exercise, you probably know how I constructed it.
I just picked a number like 6/7 and worked backwards. Once you understand how I did it, you will have no problem solving them in the future.
thanks that did help! :)
  • · Replies 17 ·
