Exam Puzzle: Will it be Disadvantageous for Jane?
  • Context: Undergrad
  • Thread starter Thread starter K Sengupta
    Puzzle
The discussion revolves around a mathematical problem concerning Jane's exam grades and whether averaging a poor grade with a higher grade would be disadvantageous for her. Participants explore various scenarios and mathematical formulations to analyze the implications of the grading options presented by the teacher.
  • Some participants propose that Jane's average grade from her exams could be compared to the average of her poor grade and a higher grade to determine if the averaging is beneficial.
  • One participant presents a specific case with grades to illustrate that it could be advantageous for Jane to average her grades, depending on the values of her grades.
  • Another participant suggests that the problem is ambiguous and may be misstated, as it does not clearly define which grade is considered the poor one.
  • Some participants argue that if Jane's poor grade is lower than her average, it may be advantageous for her, while if it is higher, it could be disadvantageous.
  • A later reply questions the clarity of the problem's wording, noting that it implies Jane's poor performance but does not explicitly state the context of her other grades.
Participants express differing views on whether the problem is advantageous or disadvantageous for Jane, with no consensus reached. Some argue for the potential advantages of averaging grades, while others highlight ambiguities in the problem's statement that could lead to different interpretations.
Participants note that the problem lacks clarity regarding the specific grades and their implications, leading to various interpretations and mathematical analyses. The assumptions about the relative values of Jane's grades are critical to the discussion.
K Sengupta
Jane took several exams in math during the academic year with grades such as a,b,c,d,e,f and once she did quite badly. When repeating the poor exam, the teacher offered that instead of the two grades, say f and A, she can have the average of the two grades.
Will it be disadvantagenous for Jane if (a+b+c+d+e+f)/6 > (f+A)/2?
NOTE:
I found this problem in a puzzle periodical.
The one line answer given in the said periodical just mentions that it would be indeed disadvantageous for Jane.
I do not know the precise methodology that would lead to the said solution, and I am looking forward to any comment from members on the foregoing matter.
Mathematics news on Phys.org
Surely there is some information missing here. Suppose
a = b = c = d = e = 20, f = A = 10
Then 18.33... = (a + b + c + d + e + f)/6
10 = (f + A)/2
so the conditions are met. However,
(a + b + c + d + e + f + A)/7 = 17.14
(a + b + c + d + e + (f + A)/2)/6 = 18.33...
So it is advantageous to average the two grades.
Let's say that M = a + b + c + d + e.
It will be disadvantageous to Jane IF the NORMAL grade she would have gotten is GREATER THAN the AVERAGED grade that the teacher is offering:
(M+f+A)/7 > (M+(f+A)/2)/6
6*(M+f+A) > 7*(M+(f+A)/2)
6M + 6f + 6A > 7M +3.5f + 3.5A
2.5f + 2.5A > M
0.5f + 0.5A > M/5
(f+A)/2 > M/5
(f+A)/2 > (a+b+c+d+e)/5
So, that's interesting. I get a slightly different outcome than in the problem, since we were hoping to get:
(f+A)/2 > (a+b+c+d+e+f)/6
or
(f+A)/2 < (a+b+c+d+e+f)/6
That means (in theory, if I did my basic algebra correctly), that there may be two instances where (f+A)/2 < (a+b+c+d+e+f)/6 is true, but one is disadvantageous, and one is advantageous. Huh. I'll have to come back to that later and see if it's correct.
DaveE
So, yes, the problem is ambiguous, or misstated.
Proof:
Assume Jane's grades are:
67,80,92,75,86, and 90, and she's making up the 90.
Case #1, Jane gets a 68 on the makeup exam. This fits the problem because:
81.667 > 79
Jane has two options.
Normal Grade:
(a+b+c+d+e+f+A)/7 = 79.71429
Averaged Grade:
(a+b+c+d+e+(f+A)/2)/6 = 79.83333
So, it will be ADVANTAGEOUS in this case for Jane.
Case #2, Jane gets a 72 on the makeup exam. This fits the problem because:
81.667 > 81
Normal Grade:
(a+b+c+d+e+f+A)/7 = 80.28571
Averaged Grade:
(a+b+c+d+e+(f+A)/2)/6 = 80.16667
So, it will be DISADVANTAGEOUS in this case for Jane.
Conclusion: Nothing. The problem is ambiguous.
My guess is that the problem is misstated, because:
Note, it appears that the problem is answerable if you assume that the grade she's making up (grade f) is actually *lower* or *equal* than the average of the rest of her grades. (I haven't proven that, but it looked that way in playing with the numbers)
DaveE
In the OP you will find that it is the lowest grade that is to be made up.
There is a counter-example in post #2 in this thread.
That's what's implied, true, but it isn't explicitly stated. It says "once she did quite badly". It does NOT say how she did the rest of the time at all-- you're just left to assume that she did worse on this one than she had done on other tests.
It may be wrong, I'm not sure (as I said I haven't tried to prove it)-- but to be a proper counter-example, you'd have to show how it's untrue, which means you have to give *two* examples, where you get answers that it's advantageous and disadvantageous.
What I'm saying is that I think (again, haven't proven it, it may be wrong, please prove or disprove it if you'd like):
If her "bad" grade is lower than her normal average, then:
(a+b+c+d+e)/5 > (a+b+c+d+e+f)/6 > (f+A)/2
And, that would mean it's actually *advantageous* to Jane, because, as I proved above, it will only be *disadvantageous* if:
It would be interesting to see how (a+b+c+d+e)/5 and (a+b+c+d+e+f)/6 relate.. Hm... let's see:
Let M = (a+b+c+d+e)
(a+b+c+d+e)/5 = (a+b+c+d+e+f)/6
M/5 = (M+f)/6
6M = 5(M+f)
6M = 5M + 5f
M = 5f
M/5 = f
(a+b+c+d+e)/5 = f
Indeed! If (as predicted) her original grade that she's making up is *less* than the average of her previous grades, then the problem is solveable, and it will be *ADVANTAGEOUS* for Jane, because:
However, if her original grade that she's making up is *greater* than the average of her previous grades, then the problem is NOT solveable because:
(a+b+c+d+e+f)/6 > (a+b+c+d+e)/5 > (f+A)/2
DaveE
It also says:
"When repeating the poor exam, ..."
I agree with you, the wording should have been less ambiguous, but I think the intent is clear.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 45 ·
16K
  • · Replies 0 ·
