Determining Tc value of various superconductors
  • Context: Graduate
  • Thread starter Thread starter leright
    Superconductors Value
The discussion revolves around determining the critical temperature (Tc) of various superconductors through resistance measurements and other methods. Participants explore the challenges of identifying Tc from resistance vs. thermocouple voltage plots, the uncertainty in measurements, and the validity of different measurement techniques.
  • Experimental/applied
  • One participant discusses the difficulty in defining the "knee" in resistance vs. temperature plots and questions how to estimate uncertainty in Tc values.
  • Another participant suggests that a typical variation in Tc could be around +/- 5K and recommends indicating the chosen Tc value clearly.
  • Some participants propose that susceptibility measurements can provide a more reliable determination of Tc compared to resistivity measurements alone.
  • There is a question about the existence of other methods to measure Tc and whether the thermal dependence of resistance plot is the most accurate method, with concerns about sensitivity to the type of superconductor.
  • Participants clarify the terminology around the thermal dependence of resistance and discuss the relevance of Hc1 in Type II superconductors.
  • One participant inquires about the measurement of diamagnetic behavior below Tc and the standard technique for measuring susceptibility using a SQUID.
  • There is a discussion on the appropriateness of using dc-SQUID vs. rf-SQUID for measurements, with differing views on ease of setup and accuracy.
Participants express differing opinions on the best methods for determining Tc and the significance of various measurement techniques. There is no consensus on a single approach or method, and multiple competing views remain throughout the discussion.
Participants mention the potential influence of the type of superconductor (soft or hard) on measurement accuracy, but this remains an unresolved aspect of the discussion.
leright
I am plotting resistance vs. thermocouple voltage (which is to be used to determine the temperature from a conversion chart) for two superconductors. I need to determine where to take the Tc value. This is difficult to determine since the "knee" is not well defined. Also, how should I guess my uncertainty in my Tc value? Are there typical criteria that physicists go by when doing these measurements?
Thanks.
Thanks.
It depends on how "accurate" you want it. What most people do is to show such a curve and then indicate where they would consider to be the value of Tc. Usually such a thing varies by, at most a +/- 5K.
If you want to be conservative, then pick the location where the resistivity flattens out at zero at the bottom of the inflection. Or you can pick the middle of the inflection and write it down with an uncertainty equal to the spread of the transition.
As long as you make it clear how you picked the value of Tc, it shouldn't be that big of an issue where you chose it. Of course, if you want to have a more accurate determination, you should accompany the resistivity measurement with the susceptibility measurement. A value consistent with both measurements is looked upon with a greater degree of certainty than simply from one.
Zz.
Do other methods to measure critical temperature exist? If yes, does the thermal dependence of resistance plot remain the most accurate one? However, is the measurement accuracy (whatever method used) sensitive to superconductor's kind (soft or hard), or what really matter is only the specific material?
Er... say what?
What is "thermal dependence of resistance plot"?
For most cases, the susceptibility measurement is considered to be the "slam-bam" evidence of superconductivity, with resistivity measurement a close second. Other supporting evidence would come from tunneling measurement that indicates for formation of an energy gap to the spectral-weight pile-up in optical conductivity measurement.
Zz.
With the thermal dependence of resistance plot I just mean the function R(Tc)... ;-) Thank you.
But in superconductors of II kind, experimentally speaking, does Hc1 give such a relevant corresponding point on the magnetization chart?
That's temperature dependence of the Resistivity, i.e. R(T), not R(Tc). That is what I said earlier about the resistivity measurement.
Yes it does. The drop in susceptibility is present no matter if it is Type I or Type II. The Meissner effect kicks in even if there are flux penetration.
Zz.
You misunderstand me about "thermal"... What about your "kicks in"? I thought the size effects may affect superconductors of Type II. How about the susceptibility measurement technique?
Thanks
Thanks
I have no idea what you just asked here. Are you asking what is a susceptibility measurement? Or are you not understanding how the drop in susceptibility occurs?
Zz.
The diamagnetic behaviour of the sample below Tc makes the internal field vanishing. How CAN this effect be measured? So, if you prefeer, what is a susceptibility measurement? Thank you
You attach a SQUID to the sample you're measuring, and stick it into a weak external field. Then you measure the susceptibility from the SQUID as you lower the temp. That's the standard technique of measuring any magnetic susceptibility.
Zz.
What is the most appropriate, dc-SQUID or rf-SQUID?
Depends on what you mean by "appropriate".
A DC SQUID (or any type of pickup coil, really), is easier to set up and measure. Often, this is the type of "good enough" results that most people want. And it is quick.
An AC SQUID requires more work, more setup, and a more accurate measurement procedure for there to be any benefit to the technique.
Zz.
  • · Replies 105 ·
14K
  • · Replies 75 ·
