| Thread Closed |
Shortest Non-Ionizing Wavelength for human body at any intensity/duration? |
Share Thread | Thread Tools |
| Nov19-06, 05:00 AM | #1 |
Hi:
What is the shortest wavelength at which light is completely non-ionizing to any and all parts of the human body regardless of duration of exposure or intensity of the light? From my own research I guess its 400nm but I could be wrong. Thanks, Radium |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov22-06, 05:00 AM | #2 |
Radium wrote:
> What is the shortest wavelength at which light is completely > non-ionizing to any and all parts of the human body regardless of > duration of exposure or intensity of the light? Given your absolute conditions, the shortest wavelength that meets your criteria is infinite. In general, X-rays and shorter-wavelength radiation can ionize essentially any atom or molecule, and radio waves and longer-wavelength radiation cannot ionize any atom or molecule, except for extremely high intensity radiation for which multiple photons can "gang up" on a single electron -- this makes the rate of ionization be many orders of magnitude lower (so much so that in practice it can be ignored), but is still not "completely non-ionizing". Ultraviolet radiation can ionize some molecules. Note that biological effects do not always require ionization, and your eyes can see without the sensing nerves being ionized, all that is required is enough energy to make the state change that fires the neuron [#]. I believe that sunburn is ionization; I'm not sure about suntanning. [#] Part of this depends on what one means by "ionization" -- the electrons are definitely pushed around the molecule, but don't leave it; so some atom within the molecule is "ionized" but the molecule itself is not. Sight is due to a chemical change in the sensing molecules, not a current generated by ionization. I believe it takes a few dozen molecules within ~0.1 second to generate a large enough signal to fire the neuron. Note also that non-ionizing radiation can cause biological damage via heating. The radiation from your microwave oven cannot ionize normal biological molecules (it works by inducing resonant vibrations in water molecules).... > From my own research I > guess its 400nm but I could be wrong. Above that wavelength the rate of ionization falls off quite rapidly, but never to "completely non-ionizing" (see above). Note the rate of ionization at a given wavelength depends rather strongly on which atom or molecule is involved. Tom Roberts |
| Nov25-06, 08:24 PM | #3 |
Tom Roberts wrote: > Radium wrote: > > What is the shortest wavelength at which light is completely > > non-ionizing to any and all parts of the human body regardless of > > duration of exposure or intensity of the light? > > Given your absolute conditions, the shortest wavelength that meets your > criteria is infinite. > > In general, X-rays and shorter-wavelength radiation can ionize > essentially any atom or molecule, and radio waves and longer-wavelength > radiation cannot ionize any atom or molecule, except for extremely high > intensity radiation for which multiple photons can "gang up" on a single > electron -- this makes the rate of ionization be many orders of > magnitude lower (so much so that in practice it can be ignored), but is > still not "completely non-ionizing". > > Ultraviolet radiation can ionize some molecules. > > Note that biological effects do not always require ionization, and your > eyes can see without the sensing nerves being ionized, all that is > required is enough energy to make the state change that fires the neuron > [#]. I believe that sunburn is ionization; I'm not sure about suntanning. > > [#] Part of this depends on what one means by "ionization" -- > the electrons are definitely pushed around the molecule, but > don't leave it; so some atom within the molecule is "ionized" > but the molecule itself is not. Sight is due to a chemical > change in the sensing molecules, not a current generated by > ionization. I believe it takes a few dozen molecules within > ~0.1 second to generate a large enough signal to fire the > neuron. > > Note also that non-ionizing radiation can cause biological damage via > heating. The radiation from your microwave oven cannot ionize normal > biological molecules (it works by inducing resonant vibrations in water > molecules).... > > > From my own research I > > guess its 400nm but I could be wrong. > > Above that wavelength the rate of ionization falls off quite rapidly, > but never to "completely non-ionizing" (see above). Note the rate of > ionization at a given wavelength depends rather strongly on which atom > or molecule is involved. > > Tom Roberts I'd put it at much longer than that. Basically, as long as there is a dipole in the anatomy (or part of the anatomy) that can absorb radiation, you can get a burn from it. A burn is usually accompanied by, if not the result of, a great deal of free radical fromation (molecular ions), and that is something that even some amateure radio enthusiasts might have experienced from touching a 100 Watt transmitter antenna at 80 meters or even longer. Water as moisture in the skin being the primary absorber in the microwave and RF cases. Frank P. Auteri |
| Jan1-07, 05:00 AM | #4 |
Tom Roberts wrote:
> Radium wrote: > > What is the shortest wavelength at which light is completely > > non-ionizing to any and all parts of the human body regardless of > > duration of exposure or intensity of the light? > > Given your absolute conditions, the shortest wavelength that meets your > criteria is infinite. > > In general, X-rays and shorter-wavelength radiation can ionize > essentially any atom or molecule, and radio waves and longer-wavelength > radiation cannot ionize any atom or molecule, except for extremely high > intensity radiation for which multiple photons can "gang up" on a single > electron -- this makes the rate of ionization be many orders of > magnitude lower (so much so that in practice it can be ignored), but is > still not "completely non-ionizing". > > Ultraviolet radiation can ionize some molecules. > > Note that biological effects do not always require ionization, and your > eyes can see without the sensing nerves being ionized, all that is > required is enough energy to make the state change that fires the neuron > [#]. I believe that sunburn is ionization; I'm not sure about suntanning. Yes. Conformational changes in a rhodopsin derived molecule in the photoreceptors causes initiation of visual response to light. This molecular-level change does not require ionization, so the specious dichotomous criterion of either "ionization" or "heating" as the only causes of biological effect from electromagnetic radiation is obviously false. Many persons with only a very basic knowledge of the biology assert that ionization and heating are the only possible effects of EM radiation; therefore, the only possible effect of microwave radiation relevant to biological function must be "heating" of one kind or another. This clearly is ignorant and false, because all visible light is nonionizing and nonheating. Lord preserve us from the idle speculations of ignorant physicists and electrical engineers! For example, just as prolonged exposure to loud but not immediately harmful sounds will cause deafness, so also will prolonged exposure to blue light in the visible range cause loss of the blue-yellow color system -- permanent damage similar in effect (but not in obvious injury) to exposure to light from an arc welder. This blue light is nonionizing (say, 480 nm wavelength); yet, it apparently irreversibly damages the blue cone photoreceptors. Mixing exposure to blue with exposure to white light or other color mixtures prevents the damage. To answer your question about effects on the skin, ultraviolet radiation is required both for tanning and for sunburn. Tanning is a response to skin damage caused by ionizing radiation. I am not certain of the mechanism, but I believe specific byproducts of the damage trigger melanocyte growth, leading to a darkening of the upper dermis. The absorption of ionizing radiation (and conversion to heat) in the darkened upper layers then protects the lower layers (and underlying blood vessels or muscle) from subsquent radiation exposure. > ... > Tom Roberts |
| Jan2-07, 05:00 AM | #5 |
On Sun, 31 Dec 2006, jwill@BasicISP.net wrote:
> Many persons with only a very basic knowledge of the biology assert > that ionization and heating are the only possible effects of EM > radiation; > therefore, the only possible effect of microwave radiation relevant to > biological function must be "heating" of one kind or another. This > clearly is ignorant and false, because all visible light is nonionizing > and nonheating. Certainly _not_ nonheating. The energy doesn't just disappear when the light does. Capable of biological effect through mechanisms other than ionisation and heating, yes. However, I suspect that most of these effects include heating as a side effect. The heating isn't always biologically significant, so perhaps it's a pedantic point. OTOH, given that many organisms deliberately exploit the heating effects of visible light ... However, it's not stupid to claim that the only significant biological effect of microwave radiation is heating, at typically encountered intensities. Perhaps wrong, but not stupid - compare energy per photon to thermal energies at room temperature. What will a single photon do? Of course, there's more to EM radiation than photons - namely, electric and magnetic fields, and these can have a wide range of effects. Some years ago, I saw some nice photos of elongated E. coli - put them in an AC field of the right frequency and amplitude, and they stop dividing. They keep growing longer and longer. But at this point, you can stop bothering about photons, or absorption of single photons. It's also not typical RF exposure. If you're willing to extend "biological effects" to include behaviour, then clearly there are non-ionising, non-heating effects in the visible, as shown by, eg TV, photos, art, etc. -- Timo Nieminen - Home page: http://www.physics.uq.edu.au/people/nieminen/ E-prints: http://eprint.uq.edu.au/view/person/...,_Timo_A..html Shrine to Spirits: http://www.users.bigpond.com/timo_nieminen/spirits.html |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Shortest Non-Ionizing Wavelength for human body at any intensity/duration?
| Relationship between light wavelength, intensity and photons energy | Introductory Physics Homework | 3 | ||
| Photovoltaic cell - relationship between wavelength and intensity of Light | General Physics | 4 | ||
| What is the shortest wavelength recorded for a photon? | General Physics | 0 | ||
| Sound Intensity and Human threshold for hearing | Introductory Physics Homework | 1 | ||
| human body levers | General Physics | 4 | ||
