I hope this helps.How high did this athlete jump?
  • Thread starter Thread starter cy19861126
    Momentum Physics
The discussion revolves around analyzing the vertical jump of an athlete using a force platform, focusing on the impulse-momentum theorem and kinematic equations. Participants are attempting to determine the height of the jump based on a force vs. time graph and the forces involved during the jump.
  • Participants discuss the impulse calculated from the area under the force vs. time graph and how it relates to the initial velocity of the jump. There are questions about how to extract mass from the graph and the implications of time intervals on impulse calculations.
There is ongoing exploration of the calculations involved, with some participants suggesting corrections to the impulse time and questioning the dimensions of the equations used. Guidance has been provided regarding the relationship between impulse and the resulting velocity, as well as the equations that can be used to find maximum height.
Participants are navigating through assumptions about the time intervals and the shape of the force graph, with some expressing uncertainty about the concepts of impulse and momentum in relation to their calculations.
cy19861126
The "force platform" is a tool that is used to analyze the performance of athletes by measuring the vertical force as a function of time that the athlete exerts on the ground in performing various activities. A simplified force vs time graph for an athlete performing a standing high jump is shown below (see attachment). The athlete started the jump at t = 0.0s. How high did this athlete jump?
My work so far:
okie, using the equation, I = p:
Ft = mvf - mvi
At the highest point, vf = 0, so...
1000N * 1.0s = -mvi
Now what do I do? I got an equation with two unknowns. I know that once you solve for vi, you can just use the equation: x = vit + 0.5at^2 to solve for x. The question is how do I get vi?
If you can't see the attachment, go to: http://students.washington.edu/cy1126/Physics.jpg
There is more information in the graph than you are seeing. What is going on before t = 0? The impulse is the area under the curve of the graph of the net force vs time.
ohhh, so you're saying that the impulse is actually 0.4N * 1.5s = 0.6Ns? So actually the equation is 0.6 = -mvi. So now what do I do next?
You can find the mass of the athelete from the graph before 0 sec. Then, plug and solve for v_i.
Hmm... I don't see what ur saying. How can u get Vi from the graph before 0 sec. Am I missing some concept here?
w=gm
Weight is in N, g is gravity, m is in kg.
Alright, I think I'm getting this. So:
w = mg
600N/9.8N/kg = 61.2Kg
Ft = mvf - mvi
Ft = -mvi
(1.5s * 400N * .5) * 1.5s = -61.2kg * Vi (in this part, do you have to divide the force by two like I did since the area under the curve is roughly a right triangle?)
Vi = -7.35 m/s
Therefore, using the equation x = Vit + 0.5at^2
x = -7.35 * 1.5 + 0.5 * -9.8 * 1.5^2 = -22.05m
The answer doesn't seem to be right. I mean at least the sign should be positive
w = mg
Ft = mvf - mvi
Ft = -mvi
Vi = -7.35 m/s
In this equation
Ft = mvf - mvi
vi is zero and vf is the velocity when he leaves the floor at the end of the impulse. vf is positive. After that it is a vertical projectile problem. Your Ft is too big. The 400N and .5 parts are good, but the time base of the triangle is not right. Not only that, it seems you have used the time twice. Ft is the area of the triangle. Check the dimensions of your equation. There can be only one time factor on the left.
You might want to use the equation that relates the change in velocity squared to the acceleration and the distance for the flight (or conservation of energy which is the same thing).
OlderDan said:
In this equation
Ft = mvf - mvi
okay, I think I kinda know what ur saying. I'll give it an another shot
Ft = mvf
400N * 1.0s * 0.5 = 61.2 kg * vf
vf = 3.26 m/s
x = vit + 0.5at^2
x = 3.26 * 1s + 0.5*9.8*1^2
= 8.16 m
Is what I am doing correct? I don't get what u said about "You might want to use the equation that relates the change in velocity squared to the acceleration and the distance for the flight (or conservation of energy which is the same thing)." Sorry about this, but I am really bad on this Impulse thing (I was doing perfectly fine on the other conservation of mometum thingy)
Ft = mvf
vf = 3.26 m/s
x = vit + 0.5at^2
= 8.16 m
I still think your time for the implulse calculation is a bit too long. If you extend the sloping line down to the .6kN line it intersects at about .3sec, so the base of the triangle is about .7sec. The time in the air has no direct connection to the impulse time. It depends only on the velocity achieved at the end of the impulse. The equation that will tell you the maximum height is
v² = v_o² + 2as
At maximum height the velocity is zero, the initial velocity is what you caclulate at the end of the impulse, and a is -g. This equation is equivalent to energy conservation
½mv² + mgh = ½mv_o²
10K
