Quartile & Percentiles Questions - Answers by Alex
  • Context: High School
  • Thread starter Thread starter alexbib
This discussion addresses the distribution of values into quartiles and percentiles, specifically focusing on scenarios with equal values and datasets that cannot be evenly divided. Alex provides clarity on quartile calculation, stating that equal values must reside in the same quartile, even if it results in unequal groups. For datasets with fewer than 100 values, he emphasizes the use of the formula for quartiles: the lower quartile is the (n+1)*0.25th number, while the xth percentile is calculated as (n+1)*x/100th number. He also mentions the option of linear interpolation for fractional indices.
  • Understanding of basic statistical concepts such as quartiles and percentiles
  • Familiarity with median calculation in datasets
  • Knowledge of linear interpolation techniques
  • Ability to work with small sample sizes in statistics
  • Research the application of quartiles in statistical analysis
  • Learn about percentiles and their significance in data interpretation
  • Explore linear interpolation methods for statistical calculations
  • Study the implications of using small datasets in statistical modeling
Statisticians, educators, and students seeking to deepen their understanding of quartile and percentile calculations, particularly in the context of small datasets.
alexbib
I have a few questions about distributing values into quartiles:
1.must all equal values be in the same quartile, even if that makes you create (sometimes very)unequal groups?
2.what do you do when your number of values cannot be divided by 4? Say I have 10 values, do I make the quartiles 3-2-3-2, 2-3-3-2, or something else?
About percentiles, what do you do when you have less than 100 values?
I know stats isn't meant to be used on small numbers of values, but I am tutoring two high school students and couldn't answer these questions.
Thanks,
Alex
I teach at 4 unis and also privately teach students. Unfortunately for you I have seen at least 4 similar ways of doing this. The most common way is that the upper quartile is the median of the upper half of the numbers. so the upper quartile of
12,13,15,19,100,102 is the median of 19,100,102 so the upper quartile is 100.
note that if the data set is odd the middle number is used in both the lower half and upper half of the numbers.
so the lower quartile of 13,15,19,100,102 is the median of 13,15,19
so lower quartile is 15.
so the upper quartile of 13,15,19,100,102 is the median of 19,100,102
so lower quartile is 100.
if you want a formula that works quartiles it the
lower quartile is the (n+1)*0.25th number.
the xth percentile would be (n+1)*x/100th number
What do you when you want the 5.25th number? take the 5th number or use linear interpolation, it depends on their skill.
14K
  • · Replies 42 ·
