Speed & Distance of Sliding Bar on Rails - Get Help
  • Thread starter Thread starter Sir_Pogo
    Sliding
The problem involves a conducting bar sliding on rails within a magnetic field, examining the effects of induced electromotive force (emf) and resulting forces on the bar's motion. The specific parameters include the bar's length, mass, initial speed, resistance, and magnetic field strength, with a focus on determining the bar's speed and distance traveled over time.
  • Participants discuss the relationship between velocity, induced emf, and the resulting current and force acting on the bar. Questions arise regarding the setup for solving the final velocity and the implications of setting velocity to zero in calculations. There is also mention of the need to write equations that describe the motion and forces involved.
Participants are actively exploring the relationships between the physical quantities involved and are attempting to derive equations that govern the motion of the bar. Some guidance has been offered regarding the application of Faraday's Law and the proportionality of force to velocity, indicating a productive direction in the discussion.
There are challenges noted regarding the mathematical treatment of the problem, particularly with respect to undefined expressions when attempting to solve for time or velocity. The discussion reflects the complexity of integrating concepts of electromagnetism with kinematics.
Sir_Pogo
Can i get some help on this problem?
A conducting bar of length L = 25.6 cm and mass M = 35.0 g lies across a pair of conducting rails. The contact friction between the bar and the rails is negligible, but there is a resistor at one end with a value R = 45.0 Ohms. Initially the rod is given an initial speed of v0 = 41.0 meters per second. There is a uniform magnetic field perpendicular to the plane containing the rod and rails of magnitude B = 1.4 T.
What is the speed of the rod at time t = 23.297 s?
How far does the rod slide before coming to rest?
Thanks in advance.
https://www.physicsforums.com/showthread.php?t=94380
the velocity induces an emf, the emf gives a current, and
the current gives a backward force F=ILB
How do i set it up to solve for the final velocity?I can't figure out how to do part two either because
setting v to zero, you cannot solve for t because ln (0)
is undefined.
is undefined.
The movement of the bar changes the flux through the loop in a way that depends on the velocity. The emf and the current are related to the rate of change of the flux. The force is related to the current and the strength of the field. The rod decelerates in proportion to the force. Start writing the equations that describe these phenomena and see if you can come up with an equation for the acceleration of the rod.
which equation is the one that deals with flux and velocity, i was trying to use these ones to solve:
F=ma=ILB
I=BLV/R
F=ma=ILB
I=BLV/R
For a constant magnetic field perpendicular to a loop, flux through the loop is Φ = BA where A is the area enclosed by the loop. The induced emf is proportional to the rate of change of flux through the loop (Faraday's Law). In this problem there is a current loop whose area is changing as the rod moves. An emf is induced, so a current flows, and the current carrying rod experiences a force that is proportional to its velocity and the field strength.
Your equations come from application of these ideas to this problem. If you combine the equations you find that the force (and hence the acceleration) is proportional to the velocity. From there you need to do some calculus to solve the problem. What function (for the velocity) do you know that is proportional to its own derivative (acceleration)?
10K
  • · Replies 25 ·
  • · Replies 22 ·
