Rubber Bands and Heating: Does Weight Go Up or Down?
  • Context: High School
  • Thread starter Thread starter daniel_i_l
    Heating Rubber Weight
The discussion revolves around the effects of heating a rubber band with a weight hanging from it, specifically whether the weight will rise or fall as the rubber band is heated. Participants explore concepts related to thermal expansion, material properties, and the behavior of rubber under heat.
  • One participant recalls being taught that heating an object causes it to expand, leading to the expectation that the weight would go down.
  • Another participant references Feynman's lectures, suggesting that heating the rubber band increases its tension, potentially causing the weight to rise.
  • One participant challenges the universality of thermal expansion, citing ice as an example that shrinks when heated, and speculates about the behavior of rubber bands under heat.
  • Another participant suggests that the composition of the rubber band may influence its behavior when heated, indicating that rubber generally softens and may stretch further.
  • A later reply mentions that for small temperature increases, the behavior may not align with expectations due to principles like Le Chatelier's principle.
Participants express differing views on how heating affects the rubber band and the weight. There is no consensus on whether the weight will rise or fall, and multiple competing hypotheses are presented.
Participants note that the behavior of rubber bands may depend on their specific composition and the extent of heating, with some suggesting that significant heating is required to observe softening effects.
This discussion may be of interest to those exploring material science, thermodynamics, or the properties of elastic materials under varying temperatures.
daniel_i_l
Suppose you have a weight hanging from a rubber band and you heat up the rubber band, will the weight go up or down? from grade-school the answer "down" was pounded into my head - obviously - when something is heated it expands! but yesterday i was reading the Feynman lectures and in the chapter about statistical mechanics he said that the rubberband actually gets shorter when heated. he explained that heating the RB gives it more tension and so it pulls harder on the weight and the weight goes up. but isn't it true that as something is heated it expands?
Thanks.
Science news on Phys.org
Not universally. A more common example is ice: heating ice will cause it to shrink. And the water you get will continue to shrink as heated, until about 4° celsius.
Heating something causes its molecules to become more energetic. More energetic particles tend to remain further apart than less energetic particles (thus expanding the object), but sometimes other considerations predominate.
For basic ice, it's because water molecules tend to organize into a sparse crystalline structure. When heated, the crystal dissolves and the molecules arrange themselves in a more random (and thus denser) fashion.
I don't know what's going on for a stretched rubber band. My first guess is that it wants to expand laterally, which makes the rubber band feel more stretched, and thus it tugs harder. I have no reason to believe that's right, though.
I guess that it would depend upon the composition of the band. Generally, I would expect it to stretch farther since rubber softens when heated. (Don't ask me how I know this; let's just put it off as a bad experience...)
Not for small increases in temperature (Le Chatelier). For most common types of rubber (polyisoprene based) the typical deflection temperatures or maximum working temperatures are from about 50C to about 250C, so it would take some serious heating to get the rubber to soften to its yield point.
PS: Some related discussion here: https://www.physicsforums.com/showthread.php?p=419641#post419641
Hmmm... interesting.
  • · Replies 66 ·
15K
  • · Replies 23 ·
  • · Replies 152 ·
12K
  • · Replies 17 ·
