| Thread Closed |
pointers .....C language |
Share Thread | Thread Tools |
| Nov25-06, 02:55 AM | #1 |
I need your help:
name1 < name 2 > name 3 I m writing a problem that place: a pointer on name 1 a pointer on name 2 a pointer on name 3 I have been working on it more than 24 hours but in vain what i did is strcmp with < if it is place ptr 1 (it works) then strcmp if there is sthg after the < place ptr 2 (it works) BUT The same procedure didn't work for the latest name PLEASE I SPEND hundreds of hour on writing my program and i m still stuck in many parts...can u help me solving this part thanks |
| Nov25-06, 12:13 PM | #2 |
A name, assuming that you made it an array of characters, will always be a pointer. Make sure you understand that completely. It would help immensely if you posted your code so I can see exactly what you're doing incorrectly.
| Nov25-06, 02:43 PM | #3 |
I don't understand your problem specification. The number one rule of computer science is that the problem specification must be spelled out clearly and non-ambiguous. You will find out this true for small assignments, and real projects.
| Nov26-06, 03:29 AM | #4 |
my problem is solved !!
Thanks all of you |
| Thread Closed |
| Thread Tools | |
Similar Threads for: pointers .....C language
| Doing a presentation. Need some pointers. | Chemistry | 1 | ||
| Coding a Bubble Sort routine using a pointer array | Programming & Comp Sci | 4 | ||
| New and looking for pointers. | General Discussion | 0 | ||
| C++ Pointers doubt | Engineering, Comp Sci, & Technology Homework | 13 | ||
| Need some pointers | Introductory Physics Homework | 21 | ||
