Acid &Base: Calculate PH of HOCl & Net Ionic Eq.
  • Thread starter Thread starter APCalculus
The discussion focuses on calculating the pH of a 0.175 M solution of hypochlorous acid (HOCl) and writing the net ionic equation for its reaction with sodium hydroxide (NaOH). The Ka expression for HOCl is established as [H3O+][OCl-]/[HOCl] = 3.2 x 10^-8. Participants confirmed the initial chemical equation for HOCl's behavior in water and calculated the moles of NaOH added during titration. The correct approach to finding [H3O+] and [OH-] after titration was emphasized, requiring a clear understanding of the net ionic equation.
  • Understanding of weak acids and their dissociation constants (Ka)
  • Knowledge of chemical equilibrium and the ICE (Initial, Change, Equilibrium) table method
  • Familiarity with titration concepts and calculations
  • Basic proficiency in writing net ionic equations
  • Learn how to derive pH from the Ka expression for weak acids
  • Study the process of titration and its impact on pH
  • Explore the calculation of [H3O+] and [OH-] in titration scenarios
  • Review examples of net ionic equations for acid-base reactions
Chemistry students, educators, and laboratory technicians involved in acid-base chemistry and titration experiments.
APCalculus
Hypochlorous acid, HOCl, is a weak acid in water. The Ka expression for HOCl is shown below:
[H3O+][OCl-]/ [HOCl]= 3.2 X 10^-8
1) write a chemical equation showing how HOCl behaves as an acid in water.
i got: HOCl + H2O = H3O + OCl
2) calculate the PH of a 0.175 M solution of HOCl.
i got:
Initial: 0.175 0 0 0
Change: -x -x +x +x
Equilibrium: 0.175-x -x +x +x
am i doing it right? how do u calculate the PH from x?
3) write the net ionic equation for the reaction between the weak acid HOCl and the strong base NaOH.
I got: HOCl + NaOH = H3O +Na +OH
is it right?
4) In an experiment, 20 mL of 0.175 M of HOCl is placed in a flask and titrated with 6.55 mL of 0.435 M NaOH.
A)Calculate the number of moles of NaOH added.
I did: (6.55/1000) x (0.435 M) = 0.0025
B) Calculate [H3O+] in the flask after the NaOH has been added.
where do i start? i don't get what the question is asking.
C) Calculate [OH-] in the flask after the NaOH has been added.
thank you.
bump, anyone?
You've forgotten to include the charges on the product ions.
i got:
Change: -x -x +x +x
The concentration of water initially is not zero, but that's not important for the calculation - it is assumed there's a sufficient excess of water to not matter.
So you've got [HOCl] = 0.175-x, [H3O+] = x = [OCl-]
Now go back to the question and look at the expression for the Ka of HOCl.
is it right?
Well, what are you supposed to get when you neutralize an acid with a base?
Correct.
Once you figure out the correct equation for (3), this will make more sense. See hint for (3).
  • · Replies 22 ·
