Lagrangian method for equation of motion
The discussion focuses on deriving the equations of motion for a system involving two equal masses connected by a spring over a massless pulley on a frictionless surface using the Lagrangian method. The Lagrangian is defined as L = T - V, where T is the total kinetic energy and V is the potential energy. The equations of motion are simplified to mx'' = -kx, leading to a second-order differential equation. The boundary conditions x=0, x'=0, and t=0 yield the solution x(t) = 0, indicating no extension occurs in the system.
  • Understanding of Lagrangian mechanics
  • Familiarity with kinetic and potential energy concepts
  • Knowledge of differential equations
  • Basic grasp of harmonic motion
  • Study the Euler-Lagrange equation in detail
  • Explore the implications of boundary conditions in differential equations
  • Learn about harmonic oscillators and their solutions
  • Investigate the effects of varying mass and spring constants on system behavior
Physics students, mechanical engineers, and anyone interested in classical mechanics and the application of Lagrangian methods to dynamic systems.
Ed Quanta
Assume a masssless pulley and a frictionless surfce constraining two equal masses. Let x be the extension of the spring from mits relaxed length. I have to derive the equations of motion by Lagrangian methods, and solve for x as a function of time with the boundary conditions x=0, x'=0, and t=0. Anyone feel like helping for a smile?
Sure, I would be happy to help! Before we dive into the Lagrangian method, let's review the setup of the problem. We have two equal masses, let's call them m1 and m2, connected by a massless spring with extension x. The spring is also connected to a frictionless surface and passes over a massless pulley. We want to derive the equations of motion for x as a function of time using the Lagrangian method, with the given boundary conditions.
To start, let's define our variables. We will use x1 and x2 to represent the displacements of m1 and m2, respectively. The total kinetic energy of the system can be written as T = 1/2 m1x1'^2 + 1/2 m2x2'^2, where x1' and x2' are the velocities of m1 and m2, respectively. Similarly, the potential energy of the system can be written as V = 1/2 kx^2, where k is the spring constant.
Now, we can write the Lagrangian L = T - V, which gives us L = 1/2 m1x1'^2 + 1/2 m2x2'^2 - 1/2 kx^2. Using the Euler-Lagrange equation, we can obtain the equations of motion for x1 and x2 as dx1/dt = dL/dx1' and dx2/dt = dL/dx2'. These equations can be simplified to mx1'' = -kx and mx2'' = kx, where x1'' and x2'' are the second derivatives of x1 and x2 with respect to time.
Since m1 and m2 are equal masses, we can combine these equations to get mx'' = -kx, where m is the mass of each mass. This is a second-order differential equation, which can be solved by using the general solution x(t) = A cos(ωt) + B sin(ωt), where A and B are constants and ω is the angular frequency given by ω = √(k/m).
Applying the boundary conditions x=0, x'=0, and t=0, we get A = 0 and B = 0. Therefore, the solution for x(t) is x(t) = 0. This means that the extension
  • · Replies 21 ·
