Mechanics - Uniform Hoop and Angular Velocity
The discussion revolves around a mechanics problem involving a heavy uniform hoop of mass M and radius R rolling on level ground and encountering a step of height h. The hoop's behavior upon impact and its angular velocity after surmounting the step are central to the inquiry, with participants exploring the implications of energy conservation and angular momentum.
  • Mixed
  • Participants discuss the application of conservation of energy and question the conditions under which the hoop maintains angular velocity after impact. There is exploration of the relationship between linear and angular velocities and the implications of the hoop's energy state before and after the impact.
The conversation is ongoing, with participants raising various interpretations of the problem and questioning the physical feasibility of the conditions described. Some have suggested that the hoop's angular velocity changes during the process, while others are examining the role of torque and angular momentum in the context of the impact.
There are discussions about the assumptions made in the problem, such as the no-rebound condition and the implications of energy conservation versus torque application. Participants express uncertainty about the physical realism of the scenario and the calculations involved.
Asrai
A heavy uniform hoop of mass M and radius R rolls in a straight line on level ground without slipping. It encounters a step of height h, where h<R perpendicular to its path. On striking the corner of the step, the hoop does not rebound and has sufficient energy to just surmount it. If the angular velocity of the hoop about the corner just after impact is omega, show that:
omega = ((g*h)^0.5)/R
I've solved this problem using conservation of energy, saying that the sum of the linear and angular kinetic energy before the impact is equal to the potential energy the hoop gains by surmounting the corner. The thing is, while the maths works out fine, I'm wondering while the hoop is still moving at all? If it's just got enough energy to surmount the corner, surely it would be stationary and not have any angular velocity?
Additionally, I'm wondering whether the omega that I've calculated is just the omega before the impact; the angular velocity that's necessary to surmount the corner.
There seems to be a contradiction in your statements. If all the kinetic energy were converted to potential energy, the hoop would no longer be moving, as you have observed. So you cannot possibly have gotten a non-zero value for ω from your calculation.
The no-rebound condition is quite artificial, but if you take that as a condition and assume the hoop stays in contact with the step there will be a torque acting on it. I doubt energy conservation is going to work for you here because the hoop would have to bounce if energy were conserved.
Oh dear.
I thought this problem sounded dodgy... But how do you then calculate omega, by approaching the problem using torque? What I don't understand it that it hast just the right energy to surmount the counter but still has angular velocity after arriving at the top- how can that possibly fit together?
Asrai said:
Oh dear.
I need to look at this again. I think I misinterpreted it. You are probably correct that what you calculated was the ω it had before it left the ground and climbed the step. Once the impact has ocurred, energy can be conserved as long as there is no slipping. I'll assume there is a clamp that grabs the wheel when it hits but is free to rotate.
OK. That's what it is. ω is the angular velocity it has before it leaves the ground and it somehow stays attached to the corner of the step and rotates to the top where it comes to rest. Could never happen in the real world, but that's OK.
I don't know about the clamp- that is the literal transcription of the problem as it is in my booklet (except that it then goes on about some other calculations). Nevertheless, if my calculations concering omega were correct (the omega before it left the ground), how can the omega after the impact that's given in the problem possibly be the same? That would mean that all the linear kinetic energy is transformed to potential energy but that angular kinetic energy is conserved- is that even physically possible?
I think you misinterpreted the problem as well, which is what got me thinking it was something other than it is. When it gets to the top, the hoop is not moving. The ω calculation is the ω it has before it leaves the ground, not when it gets to the top. At the top it is at rest.
But wouldn't the angular velocity change? In this problem, I though h to be constant, so the angular velocity would remain constant throughout the surmounting? Also, can I use conservation of energy or do I have to use torques to get to the answer?
The angular velocity does change. It goes from the value you calculated to zero as the hoop climbs the step. You can use conservation of energy for this process. The pivot point is the corner of the step. You have to assume the hoop does not slip and that it stays in contact with the step the whole time.
Ok, so I've got that bit of the problem. It then goes on:
Consider motion before and after impact and use conservation of angular momentum to show that the hoop rolls with a velocity V before impact as follows: V = beta*R*omega where beta = (2R)/(2R-h)
Now, I don't even know where to start! V is obviously bigger before the impact than after it; and V after the impact is just (g*h)^0.5. If I do all the calculations for the angular momentum, I just get V = (g*h)^0.5 as well, so I'm thinking I'm missing a detail. Is there really no external torque acting on the system?
Before impact, the hoop has an angular velocity related to its linear velocity (no slipping). After impact, it has a new angular velocity that was calculated in the first part of the problem. The force of impact from the corner of the step cannot change the angular momentum about that contact point. (There is no torque about that point until the hoop leaves the ground and gravity is no longer balanced by the normal force from the ground.)
Write an expression for the angular momentum relative to the contact point before impact using the initial angular and linear velocities. Write another expression for the angular momentum just after impact using the previously calculated angular velocity right after impact. Equate these expressions and use the linear-angular velocity relationship to solve for the angular and linear velocities just before impact.
It works. I did it.
Maybe I'm just too thick to really get that problem, but how do you do that? I've got L = M*R*(gh)^0.5 for the angular velocity right after impact; but how do I get to the expression for angular velocity right before the impact? I know that omega' = V/R, but that's about it; if I then use L = I*omega... well, it doesn't work.
You need the moment of inertia about the contact point to calculate the L after the collision. You are off by a factor of 2. Before the collision, the angular momentum about the contact point can be calculated as the angular momentum of the CM plus the angular momentum about the CM. For that you will need the moment of inertia about the CM and L written in terms of the linear and angular velocities converted to an expression in terms of one of those velocities.
Thank you so much! I'm still not quite sure whether everything I've done is quite right, but everything makes a lot more sense now!
  • · Replies 32 ·
  • · Replies 42 ·
  • · Replies 17 ·
