Register to reply
How fast does a bullet return to earth?
by satelital
Tags: bullet, earth, return
Share this thread:
satelital
#1
Feb15-04, 10:05 PM
P: 1
My question is based on a stray bullet that was shot on new years, and we discovered the it had hit the surface of our tennis court with such force that it made a hole aprox. the same size as the bullet it's self. A group of friends discussed different opinions as to how fast the bullet comes down oposed to the speed it leaves the gun, or said in other words, does it come down faster than it went up?
If anyone has a general answer (taking into consideration we do not have the exact launch speed, wind, bullet weight, etc.)
Thanks
Satelital
Phys.Org News Partner Physics news on Phys.org
Refocusing research into high-temperature superconductors
Neutron tomography technique reveals phase fractions of crystalline materials in 3-dimensions
Tiny magnets, huge fields: Nanoscale ferromagnetic electrodes create chemical equivalent of solid-state spin valve
ahrkron
#2
Feb15-04, 10:22 PM
Emeritus
PF Gold
P: 734
In a perfect vacuum, the bullet would return (to the height from which it was shot) with the same speed it had when it left the gun's barrel; in an atmosphere, part of its energy will be lost in collisions with gas molecules.
Vodka
#3
Feb15-04, 11:58 PM
P: 17
it would take the same amount of time for it to go back as it would coming down. since gravity is constant [close to the surface of earth for all practical purposes, anyways] it'll act upon the bullet with the same amount of 'pull' [for lack of better word :P]
its terminal velocity depends on on its size and mass, but i doubt it would reach. bullets are pretty aerodynamic tho, so they do go pretty fast. but you could expect it would land with roughly the same speed as it left.
suyver
#4
Feb16-04, 06:32 AM
suyver's Avatar
P: 265
I disagree: the speed of a bullet leaving the gun is typically (much) faster than the speed of sound: ~1000 m/s. Compare this to the terminal velocity of a skydiver: ~100 m/s. I'd say that there is no way that a free-falling bullet would break the sound-barrier (~300 m/s), so somewhere arround ~100-200 m/s seems like a reasonable estimate of a free-falling piece of metal.
schwarzchildradius
#5
Feb16-04, 09:17 AM
schwarzchildradius's Avatar
P: 179
I agree, it definitely does not come down as fast as it went up. If it is shot from horizontal in a vacuum, it will reach the ground at the same time as another body dropped at the height of the gun. In air, the dropped body would hit the ground first because the fired bullet is slowed down more.
There are equations for particle paths for air resistance that include atmospheric density and the velocity of the particle etc, but they are large.
Integral
#6
Feb16-04, 02:18 PM
Mentor
Integral's Avatar
P: 7,315
Originally posted by suyver
I disagree: the speed of a bullet leaving the gun is typically (much) faster than the speed of sound: ~1000 m/s. Compare this to the terminal velocity of a skydiver: ~100 m/s. I'd say that there is no way that a free-falling bullet would break the sound-barrier (~300 m/s), so somewhere around ~100-200 m/s seems like a reasonable estimate of a free-falling piece of metal.
This is a question about the terminal velocity of a bullet, a dense streamlined object designed to travel at high speeds through the air. Why would we base estimates of this on the terminal velocity of the human body? While I do not know what the terminal velocity of a bullet is, I am sure equal to or 2 twice that of a human body is on the very low end of the possibilities.
edit.
Here is a good link.
Actually the terminal velocity of a human is more like 120MPH this is about 54 m/s while that of a bullet seems to be anywhere from 100~400m/s depnending on the size and mass of the slug. (Note the high end is for a 14" Naval gun!)
FZ+
#7
Feb16-04, 02:32 PM
FZ+'s Avatar
P: 1,954
It is rather obvious that the bullet will land at a lower velocity - simple conservation of energy, and second law of thermodynamics.
suyver
#8
Feb17-04, 01:43 AM
suyver's Avatar
P: 265
400 m/s would mean that the free-falling bullet breaks the sound-barrier. Do you have a link proving this (I find it hard to believe)? I could not find this info in the link you provided.
Integral
#9
Feb17-04, 03:31 AM
Mentor
Integral's Avatar
P: 7,315
Major Julian Hatcher in his book Hatcher’s Notebook estimates that a 12 inch shell weighing 1000 pounds and fired straight up would return with a speed of 1,300 to 1,400 feet per second and over 28 million foot pounds of striking energy.
That is from the last paragraph of the link, calling a 1/2 ton of steel a bullet is a stretch. That is called a shell, Looks like the reference is given.
krysith
#10
Feb19-04, 10:54 AM
P: 23
Regarding the possibility of the bullet breaking the sound barrier in its fall - it is possible for objects to break the sound barrier while falling - just ask Joe Kittinger (google if you don't know who he is). However, of course, he exceeded the sound barrier at a very high height, where the air was thin.
In order to see whether the bullet could exceed the sound barrier, lets look at the energy gained and lost per distance fallen. The bullet will gain energy +E=d*g*m, and lose energy -E=d*Cd*p*v^2*A/2.
d=distance fallen
g=9.8m/s^2
m=mass of bullet
Cd=drag coefficient
p=density of air
v=velocity while falling
A=frontal area (from which Cd is generated)
Setting -E=+E, and solving for v, we find that v=((2*g*m)/(Cd*A*p))^1/2.
Cd at transonic speeds is about 0.45 for a bullet with an A of 5.8x10^-5 m^2 (a 7.62mm rifle bullet, AK-47). p at sea level is about 1.275 kg/m^3. m for a 7.62 mm bullet is about 0.01 kg. The terminal velocity calculated by this equation is about 76 m/s, well below transonic speed. Using the subsonic drag coefficient of 0.3, we get a terminal velocity of 94 m/s. So the bullet would come down at nowhere close to transonic speed. Nevertheless, a bullet hitting you at 94 m/s has a kinetic energy of 88 Joules, spread over a small area. It won't hurt as much as a regular bullet shot, but it will still hurt you. I'd wear a helmet if I were firing bullets in the air - people die all the time from "celebratory firing".
Integral
#11
Feb19-04, 04:16 PM
Mentor
Integral's Avatar
P: 7,315
Perhaps you did not notice..
The shell that may be breaking (is breaking according to analysis similar to yours) is from a 12" navel gun. m= ~2.2x103kg
AnthreX
#12
Feb20-04, 09:16 PM
P: 47
in my opinion the bullet shot up would be faster than the bullet dropping by the gravity force. when shooting up the potential energy should be greater than the potential energy of the bullet falling. even though when falling the gravity acts on it.
McNamara
#13
Aug14-06, 06:14 PM
P: 1
A bullet is said to travel 33,000 MpH which would obviously lose it's velocity at an upward angel. Depending on the angel in which it was shot it, it's hard to tell exactly how fast it made contact with your tennis court. To determine the speed of the bullet would be a large process involving you figuring out the approximate angel of entry, the type of bullet, gun, atmospheric pressure and other weather factors aswell as where the person shot the gun from. You would probably need to make some sort of quadratic sketch to find this out. Sorry I couldn't actually answer the question however, this should help you if you so choose to go to these great lengths.
ZapperZ
#14
Aug14-06, 06:20 PM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,239
Quote Quote by McNamara
Wow! Talk about digging up the dead! Did you know that you're responding to a post from 2004?
Zz.
russ_watters
#15
Aug15-06, 08:51 AM
Mentor
P: 22,248
Coincidentally, Mythbusters just did an episode on this very topic and found that bullets have a terminal velocity of only 100mph. Very, very surprising.
For one thing, their aerodnamics don't help because they fall on their side.
http://kwc.org/mythbusters/2006/04/e...red_up_vo.html
Rach3
#16
Aug15-06, 11:26 PM
Rach3's Avatar
P: 318
Quote Quote by russ_watters
Mythbusters are made-for-tv idiots. Look at their pathetic excuse for physical reasoning:
Adam calculated that the ballistics gel is 650x more dense than air, so, according to his theory, if a bullet fired into ballistics gel goes 1ft, it would go 650 ft through air.
Rubbish!
russ_watters
#17
Aug15-06, 11:54 PM
Mentor
P: 22,248
Read a little further. They constructed a vertical wind tunnel and dropped bullets into it.
WhyIsItSo
#18
Aug16-06, 02:14 PM
P: 185
Quote Quote by schwarzchildradius
I don't agree. The horizontal velocity of the fired bullet is irrelevant in this instance.
Both the "stationary" object dropped and the bullet fired begin with zero vertical velocity. They will accelerate downwards at the same rate, therefore hit the ground at the same time.
Register to reply
Related Discussions
The speed of a bullet may be determined by allowing the bullet to pass throu Introductory Physics Homework 9
A bullet droppet and a bullet fired Introductory Physics Homework 4
How fast is light on Earth? General Physics 12
Linear momentum: a bullet and the earth Classical Physics 7
Why is the escape velocity of Earth so fast? General Physics 6
