Finding the Cheapest Cylinder with Extreme Values: Help Needed!
  • Thread starter Thread starter me_maths
    Cylinder
The discussion focuses on optimizing the cost of constructing a cylinder with a fixed volume of 100 dm³. The cost structure is defined as 10€ per dm² for the base and 5€ per dm² for the side. The user derives the formula for the cost based on the radius (r) and height (h) of the cylinder, leading to the equation 20πr - 1000/r² = 0. The correct radius is determined to be approximately 2.52, contrasting with an incorrect calculation yielding 3.989422. The user seeks clarification on the derivative calculation and its implications for finding the optimal radius.
  • Understanding of calculus, specifically derivatives
  • Familiarity with geometric formulas for volume and surface area of cylinders
  • Basic knowledge of cost optimization in mathematical contexts
  • Ability to manipulate algebraic equations
  • Study the principles of optimization in calculus, focusing on critical points and their significance
  • Learn about the geometric properties of cylinders, including volume and surface area calculations
  • Explore cost minimization techniques in engineering and construction scenarios
  • Practice solving derivative equations to find local minima and maxima
Students in engineering or mathematics, professionals in construction cost estimation, and anyone interested in optimization problems involving geometric shapes.
me_maths
I've got kind of stuck with a problem that includes a cylinder.
First off, we know that the cylinder has a Volume of 100 litre ( V = 100 dm^3 )
but it get's abit of tricky since you are constructing this cylinder and you are trying to make the cheapest cylinder when the bottom parts of the cylinder costs 10€ / dm^2 and the side parts cost 5€ / dm^2.
HERE BEGINS MY "WORK"/GUESSING:
I've come to the conclusion that:
V = pi*r^2*h
so: pi*r^2*h = 100
also this makes: h = 100/ ( pi*r^2 )
so I figured I'd take:
10€ * pi*r^2 + 2*pi*r*h*5€
which becomes:
10€ * pi*r^2 + 2*pi*r*100/ (pi*r^2) *5€
10€ * pi*r^2 + 2*100/r *5€
then take the derivate of that:
2*10€ * pi*r - r*1000/r^2
which becomes:
2*10€ * pi*r - 1000/r
then you make then = 0 or just directly:
2*10€ * pi*r = 1000/r
then we try to make out what r is so we mix them around abit:
20 * pi * r = 1000/r
r^2 = 1000/(20*pi)
r = root(1000/(20*pi))
which gives:
r = 3.989422...
which it shouldn't, the real answer to r at this point should be something 2.52
and here is where I'm stuck, any help is appreciated :)
It should be [tex]\sqrt[3]{\frac{1000}{20\pi}}[/tex]
The derivative of this is [tex]20\pi r -\frac{1000}{r^{2}}[/tex] not
[tex]20\pi r - \frac{1000r}{r^{2}}[/tex]
ohh... thanks a lot ^.^
