Designing a Solar-Powered Water Purification Device
  • Context: High School
  • Thread starter Thread starter AnthreX
    Water
The discussion revolves around designing a solar-powered device for purifying seawater. Participants explore various concepts, materials, and methods for effectively collecting and condensing water vapor while minimizing evaporation.
  • Experimental/applied
  • One participant proposes a method using a plastic bucket and a smaller bucket to collect evaporated water, expressing concern about water vaporizing back into the smaller bucket.
  • Another participant suggests using a funnel to direct condensed water back into the smaller bucket, raising questions about sealing the funnel and preventing water loss.
  • A suggestion is made to use silicone sealant to secure the funnel and to consider the funnel's color to minimize heating effects.
  • Another participant recommends adding crumpled aluminum foil to the small bucket, though the purpose of this suggestion is questioned.
  • A participant hints at a more effective design, encouraging others to think creatively about the setup, but does not provide details in the thread.
  • One participant identifies the concept as a solar still, commonly used in marine applications, and mentions using a tube to transport purified water.
  • Another participant shares their experience with the filter funnel method, indicating it worked but expressing a desire for further improvement.
  • There is a suggestion to use a black bucket in a light environment to enhance heat absorption.
Participants express various ideas and methods, but no consensus is reached on the most effective design. Multiple competing views and approaches remain present throughout the discussion.
Participants express uncertainty about sealing methods, the effectiveness of different materials, and the overall efficiency of their designs. Some ideas depend on specific conditions that are not fully explored.
Individuals interested in solar energy applications, water purification techniques, or experimental design in environmental science may find this discussion relevant.
AnthreX
i have to design a device that can purify seawater using only solar energy
i have just one idea but still not sure it would work
the idea is to buy a plastic bucket and a long cup or long and smaller bucket. then i put the long and smaller bucket into the big plastic bucket right in the middle. than i pour the sea water into the big bucket so it surrounds the small bucket. after that i cover the big bucket with glad wrap put it in the sun. i get a pebble (rock) and place it in the middle of the glad wrap. than the water that forms on the glad warp will all gather in the center and eventually fall into the smaller bucket.. the PROBLEM IS the water formed in the smaller bucket would vapourise too
any ideas that could help me ?
yah it would but it would also keep going back into the smaller cup. i think.
what i want to do is just have some water left in the small bucket
soon as i open it. is there anyway to keep the water in the small bucket ? i just want to make it vapourise slower than the sea water in the big bucket
Put a funnel in the top of the small bucket, large end at the top small end pointing down into the small bucket, and seal around it. The water will drop down the funnel, the vapor inside will form on the underside of the funnel and drop back into the small bucket (except the small amount that will come out through the hole at the bottom, which should form on the celephane as water drops and fall back in).
hmmmm that's a good idea but how would i seal the funnel ?
and... the hole... the water from small bucket would vaporise and leak out of the hole... hmm ahhh damit! so confusing
thanx for the help
anyone have anymore good ideas ?
thanx for the help
Silicone seal would work to seal the funnel. The funnel could be opaque white to reduce the effects of the sun on heating the water in the small bucket and the amount lost through evaporation through the hole would just drop back in anyway.
Put some lighty crumpled aluminum foil in the small bucket.
Njorl
Njorl
by putting those crumpled aluminium foil in the small bucket
what does it actually do ?
i think the funnel idea is the best i got.. and that's what i had planned to do before posting it here.
but there has to be a better way. have you guyz ever done this experiment before? if u did, did u guyz use any other different idea?
what materials did u guyz use ?
thanx heaps..~
I got a good one, to prevent evaporation from the purified water.
E-mail me, and I'll send you a picture, or plan. It is to elaborate to explain in words.
It is very similar to your plan, but the purified water will not get any of the solar energy, which is what you want.
Maybe you'll figure it out yourself, so I'll give you a hint.
"Think outside of the bucket."
E-mail: rox_jason@hotmail.com
it is called a solar still
a common item on offshore small boats
or in liferafts/lifeboats
uses a tube to carry the pure water outside the still
i will be trying the experiment with the filter funnel tomorrow
and i will see if its really effective or needs more improving
Bahh!
i tried the filter funnel it worked ok but i want some more better way
experts
professors help me on this please~!
Also, make sure the bucket is black, and the surrounding area is light. All the energy will go towards the bucket.
the idea that u gave me over the email
that really helps
ta again
  • · Replies 66 ·
  • · Replies 16 ·
32K
17K
  • · Replies 52 ·
9K
