How Do You Solve This Momentum and Projectile Motion Problem?
The problem involves a bullet colliding with a block on a frictionless table, focusing on momentum and projectile motion. Participants are asked to derive expressions for the speed of the block after impact, the change in kinetic energy, and the distance traveled after falling from the table. Additionally, they consider how the scenario changes if the bullet passes through the block instead of embedding in it.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the conservation of momentum and kinetic energy, attempting to derive formulas for the speed of the block and the distance it travels after falling. There are questions about the implications of the bullet passing through the block on the time and distance of the fall.
Some participants have made attempts to simplify their expressions and clarify their reasoning, while others are questioning the validity of their calculations and assumptions. There is ongoing exploration of the effects of different scenarios on the outcomes, with hints provided for further consideration.
Participants are navigating through potential misunderstandings regarding the conservation laws and the effects of mass on the system's behavior. There is also mention of the need to consider vertical and horizontal motions separately in their calculations.
pinkpolkadots
Can anyone help me with this problem?
A bullet of mass m is moving horizontally with speed Vo when it hits and embeds in a block of mass 100m that is at rest on a horizontal frictionless table (in the diagram it isn't placed at the edge of the table, i don't know if this matters). The surface of the table is a height h above the floor. After the impact the bullet and the block slide off the table and hit the floor a distance x from the edge of the table.
Derive expressions for the following quantities in terms of m, h, Vo and appropriate constants.
a.) the speed of the block as it leaves the table
b.) the change in kinetic energy of the bullet-block system during the impact
c.) the distance x
Suppose that the bullet passes through the block instead of remaining in it.
d.) state whether the time it takes the block to reach the floor from the edge of the table would now be greater, less, or the same
e.) state whether the distance x would now be greater, less, or the same
i don't think i solved these right at all...
a.) mVo = (m+100m)Vf
Vf = (mVo)/(m+100m)
b.) KEf - KEi = change in KE
1/2(m+100m)(Vf)^2 - 1/2mVo^2 = change in KE
c.) x = Vit + 1/2at^2
x = Vft + 0
i don't know how to figure these out...
d.) would the amount of time increse becasue it has less mass??
e.) would x increase because it has more time to fall??
Thanks for any help!
Vf = (mVo)/(m+100m)
OK, but simplify that answer.
That's the first step. Keep going. (Don't leave your answer in terms of Vf.)
x = Vft + 0
Well? Solve for the horizontal distance. (Please use different letters to represent horizontal and vertical motion.)
You may as well solve these before worrying about d and e. But the hint for those two is: Does the block end up going faster or slower than in the earlier case.
Is this right??
a.) Vf = (mVo)/(m+100m)
(mVo)/m(1+100)
Vo/101
b.) 1/2(m+100m)(Vf)^2 - 1/2mVo^2 = change in KE
1/2(m+100m)(Vo/101)^2 - 1/2mVo^2 = change in KE
1/2m(101)(Vo/101)^2 - 1/2mVo^2 = change in KE
1/2m(Vo)^2 - 1/2mVo^2 = change in KE
0 = change in KE
can that be right?
Is [itex]\frac{101}{(101)^{2}}=1??[/itex]
no
i'm so confused
So why did you state that it was, when going from the 7th line to your 8th line in your previous post?
Aside from that silly little mistake, your work looks good! :smile:
so you can't cancel the 101?
pinkpolkadots said:
Is this right??
(mVo)/m(1+100)
Vo/101
Good.
0 = change in KE
can that be right?
You made a mistake simplifying the term that I bolded in red. (As arildno has pointed out.)
You can cancel one of them. (Don't forget the square!)
oh, i see.
so it would be 1/2m(Vo^2/101) - 1/2mVo^2
pinkpolkadots said:
oh, i see.
Good. Now simplify it.
1/2mVo^2(-100/101) = change in KE
for c.) can't i just use Vf=(Vo/101)
x=(Vf)t
x=(Vo/101)t
Simplify it further.
x=(Vf)t
x=(Vo/101)t
Nothing wrong with that as a first step, but you can't stop there. (You can't just leave an unknown "t" in your answer.) Now write the equation for the vertical motion and solve both equations simultaneously.
y = Vt + 1/2at^2
h = 0 + 1/2(-10)t^2
t = square root of (h/-5)
x = (Vo/101)(square root of (h/-5))
pinkpolkadots said:
y = Vt + 1/2at^2
h = 0 + 1/2(-10)t^2
You realize that square roots of negative numbers presents a problem, right?
If you take the acceleration as a = -10 m/s^2; then the final height is y = -h (since it falls a distance h).
Thanks for all the help!
I appreciate it!
I have been thinking about parts d and e, and this is what I have decided:
d.) y = 1/2at^2
-h = 1/2(-10)t^2
t = square root of (h/5)
Since the height doesn't change, the time it takes for the block to fall would stay the same.
e.) Since momentum had to be conserved, the velocity of the block would be less if the bullet went through the block.
x = Vt
That would mean that the distance would have to be smaller.
Is this correct?
Please ignore sherlock, she is simply a secretary practising her typing and p#ssing everyone off
Thanks, Hootenanny, for pointing that out so pinkpolkadots would not be further confused.
No problem, she's been doing the same in a few other forums for an hour or so.
pinkpolkadots: I haven't had a detailed look at your problem, but both your answers look good to me (provided x is the distance the block lands from the table).
yes, x was the distance the block falls from the table.
thank you!
pinkpolkadots said:
thank you!
Twas a pleasure
pinkpolkadots said:
d.) y = 1/2at^2
-h = 1/2(-10)t^2
Good thinking!
You are correct, but can you explain your reasoning quantitatively? Hint: If the bullet passes through the block, what must be true about the bullet's final speed compared to the block's final speed?
