Thread Closed
DIfferent Amounts of Oxygen in Combustion?
Share Thread Thread Tools
Feb17-04, 03:57 PM   #1
JDK
Hello,
I know I should have knowledge of this, but I can't seem to remember very well what happens in combustion reactions with a very short supply, limited supply, and abundant supply of oxygen. What is the difference? I know complete combustion hands down, but what happens in a problem such as this...
(Write a balanced equation to represent the following)
a) Combustion of butane in a very short supply of oxygen
[?] Thanks so much! I don't need answers really, just an explanation of the three categorizations and their significance while writing the equations.
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Attacking MRSA with metals from antibacterial clays
>> Femtosecond 'snapshots' reveal a dramatic bond tightening in photo-excited gold complexes
>> Beautiful 'flowers' self-assemble in a beaker
Feb17-04, 04:20 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
How "short" is a "very short supply?" How is the combustion process conducted? add butane incrementally to the limited oxygen? oxygen incrementally to the butane? mix and ignite?
Feb17-04, 04:32 PM   #3
JDK
That it does not specify. Sorry. I'm in Chem 20 and currently completing the Unit on Organic Halides and Hydrocarbon Reactions. What I posted is what the question completely is. I'm thinking, since I'm just beginning to learn organic chemistry, that the most simple assumption would be the correct one for the Q.
Feb17-04, 06:07 PM   #4
Recognitions:
My inferrence from "short" and "limited" is that less than the stoichiometric minimum for complete combustion is available --- that said, there ain't no balanced equations for such combustions without a LOT of additional data.
The "simplest" assumption I can make is that the text for the course is less than carefully written. From that point, all I can suggest to you is that somewhere in the text are comments loosely defining "short, limited, and abundant" in the author's mind, and that the author's assertions regarding the topic are what you are to "regurgitate" as an indication that you have read the material, be it correct, or not.
You have my sympathies, and I'll wish you luck on this, and if you're going to continue in chemistry, be certain to understand that some sources are more useful than others.
Feb18-04, 08:07 AM   #5
Mentor
THIS may be of use. It contains a java applet for calculating combustion products at different equivalence ratios. As you can see, non-stoichiometric combustion gets very complex.
Feb20-04, 05:24 PM   #6
You get CO instead of CO2 as a byproduct, which isnt' good.
Nautica
Thread Closed
Thread Tools
Similar Threads for: DIfferent Amounts of Oxygen in Combustion?
Thread Forum Replies
Combustion, or not Combustion? Chemistry 3
Applications of Vast Amounts of Electricity? General Physics 17
Show a sequence of amounts are a geometric series Introductory Physics Homework 4
Combustion Introductory Physics Homework 1
Amounts spent by PFers on dietary supplements General Discussion 26
