Evaluating Divergence Thm: V, S & Verify for x^2+y^2+z^2=1
The discussion focuses on evaluating the divergence theorem for the vector field V = xi + yj + zk and the surface S defined by the sphere x^2 + y^2 + z^2 = 1. The divergence theorem states that the triple integral of the divergence of V over the volume V equals the double integral of V dot normal over the surface S. In this case, calculating the divergence of V is straightforward, while integrating V.n dS requires projecting the surface into the xy-plane and using polar coordinates for both the upper and lower hemispheres of the sphere.
  • Divergence theorem in vector calculus
  • Understanding of vector fields
  • Triple and double integrals
  • Polar coordinates in integration
  • Review the divergence theorem with examples
  • Practice calculating divergence for various vector fields
  • Learn about surface integrals and their applications
  • Explore polar coordinate transformations in multivariable calculus
Students and professionals in mathematics, physics, and engineering who are studying vector calculus and the application of the divergence theorem in evaluating integrals over surfaces and volumes.
jlmac2001
I need help evaluating both sides of the divergence theorem if V=xi+yj+zk and the surface S is the sphere x^2+y^2+z^2=1, and so verify the divergence theorem for this case.
Is the divergence theorem the triple integral over V (div V) dxdydz= the double integral over S (V dot normal)dS? If so I would I evaluate it for the above problem?
Try looking these things up, (Wolfram/mathworld). And yes, verify means evaluate both sides of the equality.
Note that, in this problem, div V is very simple so the integration over the volume is trivial. Integrating V.n dS on the surface is a bit more challenging but if you "project" the surface into the xy-plane and then use polar coordinates, it should be easy. (Don't forget to do both the part of the sphere above the xy-plane and the part below!)
