Understanding the Geometric Meaning of Gradient through its Definition
  • Thread starter Thread starter Psi-String
    Geometric
The discussion revolves around understanding the geometric meaning of the gradient of a function of two variables, specifically through its definition. Participants explore how to interpret the gradient without relying on established geometric intuitions or the directional derivative.
  • The original poster attempts to derive the geometric meaning of the gradient solely from its definition, questioning how it relates to the concept of direction and rate of change. Some participants provide insights into the gradient's directionality and its relationship to the rate of increase or decrease of a function. Others discuss the mathematical representation of unit vectors and how they relate to the gradient.
Participants are actively engaging with the concept, with some providing clarifications and others exploring the mathematical relationships involved. There is a mix of interpretations regarding the geometric meaning of the gradient, and while some guidance has been offered, no consensus has been reached.
There is an emphasis on interpreting the gradient directly from its definition, which may limit the discussion to certain mathematical perspectives. Participants are also considering the implications of the gradient's direction in relation to the function's behavior.
Psi-String
Consider a function of two variable x,y , is it possible to understand the geometric meaning of the gradient just by looking its definition
[tex]\nabla f = \frac{\partial f}{\partial x} \hat{x} + \frac{\partial f}{\partial y} \hat{y}[/tex]
I can understand the geometric meaning by directional derivative
[tex]\nabla f \cdot \vec{u}[/tex] where u is unit vector
But I want to interpret gradient's geomecric meaning "just" by it's definition, could someone tell me how?
thanks a lot
I thought this was covered in every calculus book. The gradient of a function f, [itex]\nabla f[/itex], is the vector pointing in the direction of fastest increase of f. It's length is the rate of increase in that direction. Of course, that means that [itex]-\nabla f[/itex] points in the opposite direction, the direction of fastest decrease. And if you were to walk around the hill, staying at the same altitude, you rate of increase on that path would be 0: [itex]\nabla f\cdot \vec{v}= 0[/itex]: the path is perpendicular to the gradient at every point.
If you were standing on the side of hill with altitude given by z= f(x,y), then [itex]\nabla f[/itex] at your position would point up the hill in the steepest direction and its length would be the slope of the hill in that direction.
I know the geometric meaning of gradient. I just want to try to interpret it straightfowardly just from the definition
[tex]\nabla f = \frac{\partial f}{\partial x} \hat{x} + \frac{\partial f}{\partial y} \hat{y}[/tex]Why gradient has that geometric meaning??
As you said before, the rate of change of the function f(x,y) in the direction of the unit vector [itex]\vec{v}[/itex] is [itex]\nabla f\cdot \vec{v}[/itex]. Any unit vector in 2d can be written in the form [itex]cos(\theta)\vec{i}+ sin(\theta)\vec{j}[\itex] where [itex]\theta[/itex] is the angle the vector makes with the x-axis. Then the rate of change of f(x,y) in that direction is <br /> [tex]\nabla f\cdot \vec{v}= \frac{\partial f}{\partial x}cos(\theta)+ \frac{\partial f}{\partial y}sin(\theta)[/tex]<br /> <br /> What value of[/itex]\theta[/itex] makes that a maximum? Differentiate with respect to [itex]\theta[/itex] and set equal to 0:
[tex]-\frac{\partial f}{\partial x} sin(\theta)+ \frac{\partial f}{\partial y}cos(\theta)= 0[/tex]
[tex]\frac{\partial f}{\partial y}cos(\theta)= \frac{\partial f}{\partial x}sin(\theta)[/itex]<br /> so<br /> [tex]\frac{sin(\theta)}{cos(\theta)}= tan(\theta)= \frac{\frac{\partial f}{\partial x}}{\frac{\partial f}{\partial y}}[/itex]<br /> If you think of the gradient of f as pointing along the hypotenuse of a right triangle having legs of length [itex]\frac{\partial f}{\partial x}[/itex] and [itex]\frac{\partial f}{\partial y}[/itex] then you see that equation shows gradient vector points in the direction [itex]\theta[/itex] that makes the rate of increase maximum or minimum. Its easy to see that the direction <b>of</b> the gradient is the direction of maximum increase, the opposite direction is minimum increase (i.e. maximum decrease). Look at [itex]\frac{\partial f}{\partial x}cos(\theta)+ \frac{partial f}{\partial y}sin(\theta)[/itex] to see that the length of the gradient is the rate of change in that direction.[/tex][/tex]
As you said before, the rate of change of the function f(x,y) in the direction of the unit vector [itex]\vec{v}[/itex] is [itex]\nabla f\cdot \vec{v}[/itex]. Any unit vector in 2d can be written in the form [itex]cos(\theta)\vec{i}+ sin(\theta)\vec{j}[/itex] where [itex]\theta[/itex] is the angle the vector makes with the x-axis. Then the rate of change of f(x,y) in that direction is
What value of [/itex]\theta[/itex] makes that a maximum? Differentiate with respect to [itex]\theta[/itex] and set equal to 0:
[tex]\frac{\partial f}{\partial y}cos(\theta)= \frac{\partial f}{\partial x}sin(\theta)[/itex]<br /> so<br /> [tex]\frac{sin(\theta)}{cos(\theta)}= tan(\theta)= \frac{\frac{\partial f}{\partial x}}{\frac{\partial f}{\partial y}}[/itex]<br /> If you think of the gradient of f as pointing along the hypotenuse of a right triangle having legs of length [itex]\frac{\partial f}{\partial x}[/itex] and [itex]\frac{\partial f}{\partial y}[/itex] then you see that equation shows gradient vector points in the direction [itex]\theta[/itex] that makes the rate of increase maximum or minimum. Its easy to see that the direction <b>of</b> the gradient is the direction of maximum increase, the opposite direction is minimum increase (i.e. maximum decrease). Look at [itex]\frac{\partial f}{\partial x}cos(\theta)+ \frac{\partial f}{\partial y}sin(\theta)[/itex] to see that the length of the gradient is the rate of change in that direction.[/tex][/tex]
I see... thanks a lot
  • · Replies 18 ·
