What is the specific heat of the metal?
The discussion focuses on calculating the specific heat of a metal using a heat transfer equation. The scenario involves a 9.0 kg metal container with 17.6 kg of water and a 2.0 kg piece of the same metal at 200.0°C, resulting in a final temperature of 17.1°C. The equation used is [C(metal)*Mass(container)*deltaT(container)] + [4186*Mass(water)*deltaT(water)] = Cmetal*Mass(piece)*deltaT(piece). Participants emphasize the importance of using correct units and the specific heat of water, which is approximately 4.2 J/g°C.
  • Understanding of heat transfer principles
  • Familiarity with specific heat capacity calculations
  • Knowledge of unit conversions, particularly between grams and kilograms
  • Basic algebra for solving equations
  • Review the concept of specific heat capacity and its formula
  • Practice unit conversion techniques, especially for mass and energy
  • Explore heat transfer problems involving multiple substances
  • Learn about calorimetry and its applications in thermal physics
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer and specific heat calculations.
hatingphysics
A metal container, which has a mass of 9.0 kg contains 17.6 kg of water. A 2.0-kg piece of the same metal, initially at a temperature of 200.0°C, is dropped into the water. The container and the water initially have a temperature of 15.1°C and the final temperature of the entire system is 17.1°C. Calculate the specific heat of the metal.
I used this equation but I still can't seem to get the right answer...[C(metal)*Mass(container)*deltaT(container)] + [4186*Mass(water)*deltaT(water)] = Cmetal*Mass(peice)*deltaT(piece)
HELP PLEASE!:confused:
Your equation seems correct. Just make sure your mass is in grams and that the specific heat of water that you use is about 4.2 (I noticed you forgot to put a decimal there...or was that a typo?).
If you write out your steps you took, maybe one of us can help determine where your error lies.
it's not a typo. He did not present us with his units. This is the specific heat of water in J/kg.
10K
