Ferry Velocity and Passenger Motion: Solving for Direction and Magnitude
The problem involves a passenger walking on a ferry that is moving towards a dock. The passenger's velocity is given in two different frames of reference: relative to the ferry and relative to the water. The goal is to determine the ferry's velocity relative to the water based on these velocities.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss vector addition as a method to solve the problem, suggesting the use of diagrams to visualize the relationships between the velocities. There are attempts to clarify the setup of the problem and how to express the relationships mathematically.
Some participants have offered guidance on using vector addition and suggested drawing a diagram to aid understanding. There is an ongoing exploration of how to set up the problem correctly, but no consensus has been reached on a specific solution approach.
The problem is noted to have a confusing wording, which may contribute to the difficulty in interpreting the setup and relationships between the velocities involved.
tgoot84
HELP please: vector angles and velocity
Alright i don't nessesarily need an answer for this but maybe just a way to set it up. The problem is worded weird and no one can figure it out.
A passenger walks from one side of the ferry to the other side as it approaches a dock. If the passenger's velocity is 1.2 m/s due north relative to the ferry, and 4.5 m/s at an angle of 35 degrees west of north relative to the water, what are the direction and magnitude of the ferry's velocity relative to the water?
(blank) degrees west of north
(blank) m/s
You just have to do some vector addition.
[tex]\vec v_{f/w} + \vec v_{m/f} = \vec v_{m/w}[/tex]
where f = ferry, w = water, and m = man, and / = with respect to.
Drawing the triangle formed by the three vectors may help. Can you take it from there?
The passenger's velocity relative to the water equals the vector sum (the resultant) of her velocity relative to the ferry plus the ferry's velocity relative to the water.
So
Pw = Pf + Fw
In your problem Fw is the unknown. Set up a diagram illustrating this vector addition & solve it using simple trig.
How does this keep happening James?:smile:
  • · Replies 16 ·
