Lipschitz Continuity & Uniform Continuity: Showing sinx & cosx in R
Lipschitz continuity implies uniform continuity, which is demonstrated through the functions sin(x) and cos(x) on the real line R. The key to this proof lies in the relationship between delta and epsilon, specifically using the formula delta = epsilon/k, where k is the Lipschitz constant. This establishes that Lipschitz continuity, being a global property, guarantees uniform continuity, which is an extension of local continuity. The discussion emphasizes the importance of clearly defining these concepts to facilitate understanding.
  • Lipschitz continuity
  • Uniform continuity
  • Definitions of continuity
  • Understanding of delta-epsilon proofs
  • Study the formal definitions of Lipschitz and uniform continuity
  • Explore delta-epsilon proofs in real analysis
  • Investigate the implications of Lipschitz continuity on differentiable functions
  • Examine examples of uniformly continuous functions beyond sin(x) and cos(x)
Students of real analysis, mathematicians, and educators seeking to deepen their understanding of continuity concepts and their implications in mathematical proofs.
barksdalemc
Show that Lipschitz continutity imples uniform continuity. In particular show that functions sinx and cosx are uniformly continuous in R.
I said that if delta=epsilon/k that Lipschitz continuity imples continuity. Now I am stuck as to how to show uniform continuous.
What are the relevant definitions? Note that Lipschitz continuity is a global property of a function, and uniform continuity is the global version of the local property of ordinary continuity, so it should be straightforward to modify your proof for this case (if it doesn't already apply).
As StatusX said, write out the definitions. What is the difference between "continuous" and "uniformly continuous"? (Your "delta=epsilon/k" contains everything you need.)
  • · Replies 40 ·
