Which weight will upset this table
  • Thread starter Thread starter Scott55
    Table Weight
The problem involves determining the smallest weight required to upset a table with a uniform circular top weighing 80N and supported by four legs. To solve this equilibrium problem, one must consider the concept of torque, where the torque of the added weight must balance the torque of the table. The calculation reveals that the smallest weight needed to tip the table is 160N, achieved by placing the weight at the maximum distance from the center, which is 0.5m. This analysis provides a clear method for approaching similar equilibrium problems.
  • Understanding of equilibrium concepts in physics
  • Knowledge of torque calculations
  • Familiarity with the principles of rotational motion
  • Ability to visualize and analyze forces acting on objects
  • Study the principles of rotational equilibrium in physics
  • Learn about torque and its applications in real-world scenarios
  • Explore problems involving static equilibrium and force balance
  • Investigate the effects of varying distances from pivot points on torque
Students of physics, engineers, and anyone interested in understanding equilibrium and torque in mechanical systems will benefit from this discussion.
Scott55
This is an equilibrium problem. I do not know where to start, I usually do not run into this problem but for some reason I cannot start this problem.
Here is the question: Given a table with four light legs equally spaced around the circumference of a uniform circular top weighting 80N, find the smallest weight that, when placed on the table, will be able to upset it.
Thank you.
First draw yourself a picture of the table and the four legs. Where is the best place to push down if you wanted to tip it over? (Hint: it's not the center!)
To find how much weight you need, first find the fulcrum about which the table will tilt. Then consider rotational equilibrium about that point. When the torque of the added weight just balances the torque due to the weight of the table, the table will start to tip.
To solve this problem, we need to consider the concept of equilibrium. In order for the table to remain stable, the forces acting on it must be balanced. This means that the weight of the table, 80N, must be counteracted by the weight of the object placed on it.
To determine the smallest weight that can upset the table, we need to find the point at which the table becomes unbalanced. This occurs when the weight of the object is greater than the weight of the table. In other words, the object needs to exert a force that is greater than 80N in order to upset the table.
To find this weight, we can use the concept of torque. Torque is the force that causes rotation and is calculated by multiplying the force by the distance from the pivot point. In this case, the pivot point is the center of the table.
We can set up an equation to represent this situation:
Torque of table = Torque of object
The torque of the table is given by 80N x 0, as the distance from the center to the legs is 0. The torque of the object is given by the weight of the object, W, multiplied by the distance from the center to where it is placed, which we can call r.
80N x 0 = W x r
We can rearrange this equation to solve for W:
W = (80N x 0) / r
Since we are looking for the smallest weight that can upset the table, we want to find the smallest value of W. This occurs when r is the greatest possible distance from the center. In this case, the greatest possible distance is half of the diameter of the table, or the radius. This means that r = 0.5m.
Plugging this value into our equation, we get:
W = (80N x 0) / 0.5m = 160N
Therefore, the smallest weight that can upset the table is 160N. Any weight greater than this will cause the table to become unbalanced and upset. I hope this helps you to understand how to approach and solve this type of equilibrium problem.
17K
9K
