What is the Bandwidth of a Second Order System?
  • Thread starter Thread starter LM741
    Bandwidth System
The discussion revolves around the definition and calculation of bandwidth for second order systems, particularly in the context of transfer functions. Participants explore the implications of bandwidth definitions for different system orders and types, including low-pass and bandpass systems.
  • One participant asserts that the bandwidth of a system is defined as the frequency range where the signal's power drops by -3dB for first order systems, questioning if this changes to -6dB for second order systems.
  • Another participant clarifies that the -3dB point is generally used for measuring bandwidth regardless of the system order, particularly for bandpass systems.
  • A participant provides a specific transfer function, H(s) = 1/(s+4)^2, and argues that the bandwidth cannot be defined as w=4 due to a -6dB drop at that point.
  • There is a discussion about the distinction between power and voltage transfer functions, with a participant noting that -3dB corresponds to a half power point, not a half signal point.
  • Another participant suggests solving for the value of s_0 such that H(s_0) = 1/√2 H_max to find the bandwidth.
Participants express differing views on the definition of bandwidth for second order systems, with no consensus reached on whether it should be defined by -3dB or -6dB. The discussion remains unresolved regarding the implications of these definitions for specific transfer functions.
Participants reference the importance of distinguishing between power and voltage in the context of bandwidth definitions, highlighting potential limitations in understanding based on these distinctions.
LM741
hey all.
i read that the definition of the bandwidth of a system is the frequency range up until the signal's power (at DC) drops by -3dB.
This obviously only applies to a first order system , right?
Surely for a second order - it is defined as the range of frequency up until the power drops by -6dB?
thanks
Your first statement applies to a low-pass function. If the transfer function is a bandpass, then the bandwidth is generally measured to the 3dB points on either side of the passband. It doesn't matter what order the system is, you usually use the -3dB points as the shoulders.
Thanks - but the reason why asked the above is because i am given the following system: H(s) = 1/ (s+4)^2, and asked to find the bandwidth of the system.
It can't be w=4 (If we wish to conform to the definition of bandwidth), because at this point we have a -6dB power drop.
On the other hand, if i was given the system as: H(s) = 1/(s+4), then the bandwidth would be equal to 4, i.e w=4
thanks again
Is your H(s) a power or voltage transfer function? Remember that -3dB is not the 1/2 signal point, it's a 1/2 power point. The signal at -3dB is [tex]\frac{1}{\sqrt2}[/tex]
power = signal drops by half DC value (or DC power??).
voltage or current = signal drops to 70 percent of DC value.
They are still both regarded as -3dB points by applying the corresponding equation:
for power : 10 log(P/2)
for voltage or current :20 log(V/srt(2)).
thanks
It can be seen as a voltage ...but i don't think in this case it will make a difference...
any sugestions guys...?
I would solve for the value of [itex]s_0[/itex] such that [itex]H(s_0) = \frac {1}{\sqrt 2} H_{max}[/itex]. Since the max is clearly 1, just solve for the denominator of H(s) [tex](s+4)^2 = \sqrt {2}[/tex]
thanks - also thought about doing it that way and sticking to the definition.
  • · Replies 19 ·
9K
  • · Replies 19 ·
