Creating a Sound Card Oscilloscope Probe | How-To Guide
  • Thread starter Thread starter Rebel
    Probe
The discussion revolves around the use of a sound card and software as an oscilloscope, specifically focusing on how to create a probe that can be connected to a sound card's input. Participants explore the feasibility of this approach for audio and radio frequency applications, as well as share experiences and recommendations regarding software and hardware options.
  • Homework-related
  • One participant inquires about using a sound card with software as an oscilloscope and seeks guidance on creating a suitable probe.
  • Another participant suggests that for audio frequencies, simple wires can suffice, while noting that radio frequencies would require more specialized equipment.
  • A different participant mentions the existence of dedicated PCI cards for oscilloscope use, expressing concerns about their high cost compared to standalone units.
  • One contributor shares their experience with a B&K oscilloscope, highlighting its reliability for audio testing and questioning the sound card's ability to accurately read low frequencies.
  • A participant states their intention to use the setup primarily for audio equipment repair and design.
  • Another suggests using an older computer as a test machine for experimentation, cautioning about the sound card's voltage tolerance.
  • Several participants discuss various software options for using sound cards as oscilloscopes, mentioning programs like WinScope and their availability as freeware or shareware.
  • One participant notes that certain Linux distributions include oscilloscope software as an installation option.
  • Another participant expresses frustration over the high cost of oscilloscopes and protoboards, sharing a recent purchase experience.
Participants express a range of opinions on the practicality and effectiveness of using sound cards as oscilloscopes, with some agreeing on the use of simple wires for audio frequencies, while others emphasize the limitations of this approach for more advanced applications. There is no consensus on the best method or equipment to use.
Participants mention various limitations regarding the sound card's frequency response and voltage tolerance, as well as the availability and quality of software options, which remain unresolved.
This discussion may be useful for hobbyists, students, or professionals interested in audio testing, electronics repair, or those exploring cost-effective alternatives to traditional oscilloscopes.
Rebel
Any one ever use a sound card + software as an oscillscope?
I just want to know how i can make a probe to use as an oscillscope probe that can be plugged into the Input of a sound card.
Thanks
Computer science news on Phys.org
For audio frequencies, the probe from a multimeter will be fine. That is to say, a piece of wire will do. However, at radio frequencies, you would require a good oscilloscope with some decent probes. But for a sound card and some software, 2 wires will be sufficient.
emu,
I haven't seen a sound card thingy before, but I have seen special made PCI cards that come with all the needed cables/probes to take measurements with. The problem I have with those things is that they still cost you hundreds and hundreds of dollars, at least the ones I saw ($300 U.S. and up). For that kind of money I'd rather spend a few hundred more and get a stand alone unit.
Yeah thatnks that is what i figured is that i can use just wires
When I was 16, I managed to salvage a nice B&K oscilloscope, good to about 20 MHz. It's a pain in the ass to lug around but when I need it, it's the only tool I trust. I've tried some software for use with soundcards using the line-in as a scope but there are limitations.
I use mine mostly for audio testing, and often for bass frequencies. I doubt a sound car will read flat down to about 10 Hz while a good scope will.
What are you going to use it for?
Im going to use it for mainly audio purposes. So i can repair audio equipment and design audio as well.
If you have an old pentium 133 or something low-level with a soundcard, use that as your test machine. You can afford to fry the soundcard a few times while learning. However, be careful using this scope to repair active components. I don't even know what kind of voltage a soundcard can endure. I'd imagine the input impedance is the standard 10K so keep that in mind. A scope is in the Megaohm range.
Where might I download a trial version of the 'sound-card software' so as to experiment with it?
I download a program called WinScope but there are plenty of oscilloscope programs out there that use your sound card and a computer. Most I've seen are either freeware or shareware. But i haven't tested any of the programs yet so i don't know how good they are but I am going to eventually go out and purchase a scope.
Just to add in that Mandrake Linux (and probably other distribs) come with it as an option to install. Would be nice to get a decent O scope for less then $1000.
It would but that damn scopes are so expensive.
I got an O-scope about a month ago from www.testequipmentdepot.com.[/url] It does everything I need for my piddling and the price wasn't too bad. [url]http://www.testequipmentdepot.com/instek/oscilloscopes/gos-620.htm[/URL]
What I don't get is why protoboards are so expensive. :( Mine burned up last night right when I'm trying to work on my final project for instrumentation class too. It was very old.
  • · Replies 30 ·
9K
  • · Replies 21 ·
  • · Replies 46 ·
