| Thread Closed |
Coriolis force |
Share Thread |
| Dec13-06, 10:52 AM | #1 |
Coriolis force
I need some help,...
On the surface of the earth a cartesian coordinate system _E will be installed at the latitude ϕ. The axes of the coordinate system are aligned as following: _x1-axis: points up _x2-axis: points north _x3-axis: points east The underscores in front of the variables are a reminder that these variables relate to the non-inertalsystem _E. The exercise I should solve asks the question: How does the coriolis force depend on the latitude? In the book I read, the coriolis force was deduced to the following formula: _Fc = -2*m*(w x _r') (two times the mass multiplied with the cross product of the angular velocity with the derivative of the position vektor, where the position vector is relating to the _E-system) Now my problem: Isn't there something missing in this formula? Because as I understand the coriolis force, the distance of the motion to the axis of rotation is of importance when calculating the coriolis force. But in this formula above, the position vector relates to the _E-system, so the distance to the axis of rotation is nowhere to be found in the formula. The result as it reads in the book: _Fc = -2*m*w*(_x3'*cos(ϕ) - _x2'*sin(ϕ), _x1'*sin(ϕ), -x1'*cos(ϕ)) where _r = (_x1, _x2, _x3) Can somebody explain to how I must understand this exercise. I'm pretty sure the book is correct. What am I missing? I really would appreciate any help... --edit sorry, missed the right subforum for this thread |
| Dec13-06, 02:36 PM | #2 |
Recognitions:
| Dec13-06, 05:30 PM | #3 |
As far as I can remember that formula is correct, it assumes that the position is measured as a latitude (see polar co-ordinates) and that the velocity has no upward component
| Dec14-06, 11:42 AM | #4 |
Coriolis force
Thanks for the answers!
I have almost exactly the same problem with the centrifugal force, for which the formula _Fz = -m*(w x (w x _r)) was deduced(in relation to the exercise in my first post). Now here again there is no distance to the axis of rotation. How can this be explained? Sorry if these questions are kind of silly, but I just want to understand it correctly. |
| Dec14-06, 01:51 PM | #5 |
Recognitions:
The centripetal force does depend on the distance from the axis. It is in the ω x r product. ω and r have constant magnitude, but the angle between them depends on lattitude. Figure out what the angle dependence is and you will find a product of factors that equals the distance from the axis. |
| Dec14-06, 02:18 PM | #6 |
1-Why should r have a constant magnitude? It depends on the time, doesen't it? 2-When you talk about the position vector r, you talk about it in relation to the _E-system, the system installed on the surface of the earth? |
| Dec14-06, 10:55 PM | #7 |
Recognitions:
I do not think the r is what you think it is. It is the positon vector from the center of the earth to the particle. It can be expressed in different coordinate systems, but it is the same vector. Take a look at the first 8 pages of this http://twister.ou.edu/PM2000/Chapter7.pdf |
| Dec15-06, 11:27 AM | #8 |
I read the link you gave me, and its more or less similar to the theorie within the book I read and where the exercise is from, but its not as confusing! I should have been more carefully when describing my problem! Let's see if I can do it a little better! The equation of motion in my book is: m*_r'' = F - r0'' - m*w x (w x _r) - m*(w' x _r) - 2*m*(w x _r') where F = some real force (like gravity) _Fz = - m*w x (w x _r) = centrifugal force _Fc = - 2*m*(w x _r') = coriolis force _Fd = - m*(w' x _r) = some other apparent force which I dont know, but is of no relevance if w=const r0'' = the position vector from the origin of a fixed E coordinate system (e.g. at the center of the earth) to the accelerated _E-System at the surface of the earth. Now I would think that the coriolis force (or centrifugal force) would need the vector r0 in someway to be correct. Because I think, that the vector r is not the same as the vector _r. r = r0 + _r. Hence the coriolis force should be: _Fc = - 2*m*(w x (r0 + _r)') But in my book the formula isn't used that way, and thats exactly what's confusing me... I hope you understand what Im trying to say! |
| Dec16-06, 12:41 PM | #9 |
Recognitions:
m*_r'' = F - m*r0'' - m*ω x (ω x _r) - m*(ω' x _r) - 2*m*(ω x _r') In the constant ω case, the first two terms after F in this equation are in fact - m*ω x ω x( r0 + _r) because ω x ω x r0 is the centripetal acceleration r0'' (the only acceleration for constant ω; and here the derivative is wrt the inertial reference frame) of the origin of the rotating coordinate system. In the Coriolis term that you have written _Fc = - 2*m*(ω x (r0 + _r)') the derivative wrt time is the derivative in the rotating coordinate system, where r0 is a constant. So this reduces to the term in the book equation. The term with the ω' only comes in if the rotation is accelerating. If you go through the derivation in the link I posted, being careful to distinguish between the derviatives wrt time in the different frames and write r as r0 + _r, the book's equation will come out for the constatant ω case. If ω is not constant, then the r0'' term includes the contribution from ω' x r0 which is the tangential acceleration of the origin on the rotating coordinate system. |
| Dec17-06, 03:33 AM | #10 |
I think I got this part! If I'm calculating the centripetal acceleration form the viewpoint of the _E-System, I need to inlcude the r0 vector in my calculations. The part I have marked in the quote, what does that mean? I am also not sure if Im understanding you correctly when you use the term 'wrt time', is this a shortform for 'derivative with respect to time'? Other than that, the centripetal force chapter can be closed, thanks! |
| Dec17-06, 09:04 AM | #11 |
Recognitions:
I don't understand what you mean by your last sentence, but the result does not depend on that. The vector r0 is constant in magnitude, but not in direction in the inertial frame. A change in r0 in that frame is tangent to the constant-latitude circle on the earth's surface. From the geometry you can see that the rate of change of that vector in the inertial frame is (dr0/dt)_inertial = ω x r0 In the rotating frame, with the origin fized at the surface of the earth the vector r0 is drawn from the center of the earth at coordinates (0, 0, -r0) to the origin. This is constant in time in the rotating frame. Furthermore, the basis for all of this calculation is that the difference between time derivatives in the two frames for any vector A is (dA/dt)_inertial = (dA/dt)_rotating + ω x A Substituting r0 for A and using the know derivative of r0 in the inertial frame you have (dr0/dt)_inertial = (dr0/dt)_rotating + ω x r0 = (dr0/dt)_rotating + (dr0/dt)_inertial 0 = (dr0/dt)_rotating Note that if A = ω (or any vector parallel to ω) (dω/dt)_inertial = (dω/dt)_rotating + ω x ω = (dω/dt)_rotating + 0 (dω/dt)_inertial = (dω/dt)_rotating |
| Dec17-06, 09:23 AM | #12 |
I think I finally understood it and I got no question unanswered!
Thanks for the time you took to help me, I appreciate it a lot. |
| Thread Closed |
Similar discussions for: Coriolis force
| Coriolis force | Classical Physics | 12 | ||
| coriolis force | Advanced Physics Homework | 3 | ||
| Tea and the Coriolis force | General Physics | 18 | ||
| Coriolis Force | Introductory Physics Homework | 1 | ||
| Coriolis force | Earth | 1 | ||
