What is the absolute viscosity of the medium lubricating oil in N×s/m2?
The discussion revolves around calculating the absolute viscosity of medium lubricating oil based on given parameters such as specific gravity, pipe dimensions, flow rate, and pressure drop. The context is primarily homework-related, focusing on fluid dynamics principles.
  • Homework-related
  • Chad presents a problem involving the calculation of absolute viscosity using parameters like specific gravity, pipe length, diameter, flow rate, and pressure drop.
  • Chad expresses confusion regarding the equation provided by the professor, particularly the significance of the constant "32" and the absence of pi/4 in the equation.
  • Another participant suggests that the equation referenced by the professor pertains to laminar flow and encourages checking the Reynolds number to confirm the flow regime.
  • This participant provides a brief derivation of the equation, explaining the relationship between volumetric flow rate and the pressure drop in the context of laminar flow.
  • Chad acknowledges the clarification regarding the "32" and expresses gratitude for the assistance.
Participants generally agree on the relevance of the equation for laminar flow and the significance of the constant "32," but the discussion does not reach a consensus on the overall approach to solving the problem.
The discussion does not resolve the mathematical steps necessary for calculating viscosity, nor does it clarify the assumptions regarding flow conditions or the applicability of the equations used.
archeryguru2000
Medium lubricating oil, of specific gravity 0.860, is pumped through 300 m of horizontal 50-mm-diameter pipe at the rate of 0.00114 m3/s. If the drop in the pressure is 200 kPa, the absolute viscosity of the oil in N×s/m2 is...____________?
specific gravity (SG) = 0.86
length (l) = 300 m
diameter (d) = .05 m
flow rate (Q) = 0.00114 m^3/s
Pressure drop (P) = 200E3 Pa
I know that:
shear stress (t) = viscosity (mu) * velocity gradient
where:
velocity gradient = (change in velocity) / (change in height)
I'm not quite sure how to begin with this. I have a solution from my prof. (this is a question on a sample/practice exam for our final)... but I have NO clue where he's coming up with this equation:
P = 32 * (mu) & (l) * [(v)/(.05m)^2]
Where on Earth does the 32 come from? What significance does the (.05m)^2 have... without pi/4 anyway? Can anyone make any sense of this? The solution is supposed to be... approximately 0.09 (N s) / (m)^2. Let me know if anybody has any ideas.
Thanks,
~~Chad~~
You would have to check Reynolds number, but your prof references an equation for pressure drop in the laminar flow regime. You need to back through the proof for the equation, but the 32 comes from:
[tex]Q = \frac{\pi R^2 V_c}{2}[/tex]
[tex]V = \frac{\pi R^2 V_c}{2 \pi R^2}[/tex]
[tex]V = \frac{V_c}{2}[/tex]
Therefore
[tex]V = \frac{\Delta p D^2}{32 \mu L}[/tex]
In stead of going through the entire derivation, go here and look under the section "Volumetric Flow Rate."
http://www.ae.su.oz.au/aero/fprops/pipeflow/node7.html
Thank you sooo much. This does clear up the issue with the "32" that I had a problem with.
Thanks,
~~Chad~~
Glad to be of assistance archeryguru2000.
  • · Replies 45 ·
9K
19K
