Falling Back to Orbit: Can Rockets Change Their Orbit?
  • Context: Undergrad
  • Thread starter Thread starter wimms
    Falling Orbit
Rockets achieve and maintain orbit primarily through velocity, which is influenced by gravitational forces. To ascend to a higher orbit, rockets must increase their velocity by firing engines in the direction of travel. Conversely, to descend to a lower orbit, rockets decelerate by firing engines against their direction of travel. Firing engines towards the center of the planet alters the rocket's trajectory, resulting in a new, more eccentric orbit that does not return to the original path.
  • Understanding of orbital mechanics
  • Knowledge of rocket propulsion systems
  • Familiarity with concepts of perigee and apogee
  • Basic physics principles related to velocity and gravity
  • Research "orbital mechanics and velocity changes" for deeper insights
  • Study "rocket propulsion and thrust vectoring" techniques
  • Explore "eccentric orbits and their characteristics" in space missions
  • Learn about "gravity assists and orbital transfers" for advanced maneuvers
Aerospace engineers, physics students, and anyone interested in the mechanics of rocket flight and orbital dynamics will benefit from this discussion.
wimms
I understand that to get to orbit and stay there, rocket needs only velocity. Its velocity around planet and gravity defines the height of orbit. To change to higher orbit, rocket is firing engines to speedup rocket, to go to lower orbit, rocket fires to slow down.
I assume that engines are fired in back direction of travel. So I had this thought, what is supposed to happen if rocket fires engines towards center of planet? If it standed on surface, it would take off and when engines cut off, would fall back down. So, if rocket would fire engines in direction towards center of planet, so as to climb higher, is this going to happen? And when it stops burner, is it going to "drop" back to its previous orbit? I guess so.
And if opposite, rocket firing into open space so as to "dive" towards center of planet - as long as engines fire, it does. But when engines stop, is its velocity throwing it back up into its previous orbit? Seems kinda funny.
Astronomy news on Phys.org
Firing the rocket inwards or outwards from the planet would put the rocket in a new, more eccentric, orbit than the one it started in. The new orbit would have a closer perigee and further apogee than the old orbit, and would cross the old orbit at two points. The rocket will not return to its old orbit.
  • · Replies 23 ·
  • · Replies 86 ·
9K
