How to Find Logarithmic Equations from Points and an Asymptote?
  • Thread starter Thread starter Cummings
    Logarithmic
The discussion revolves around finding logarithmic equations from given points and an asymptote. The original poster seeks assistance with a problem involving three unknowns, two points, and one asymptote, specifically in the context of logarithmic or exponential functions.
  • Mixed
  • Participants explore the relationship between points and asymptotes in determining unknowns in logarithmic equations. The original poster suggests estimating a third point based on proximity to the asymptote. Others question the accuracy of this approach and emphasize the importance of precision in mathematical calculations.
Some participants have provided guidance on utilizing the asymptote to formulate equations, while others have pointed out the need for clarity in the original poster's question. There is an ongoing exploration of how to effectively use the given points and asymptote to solve for the unknowns.
The problem involves an asymptote at x = 3, and the equation format is given as Alog[base e](x-b)+c, with specific points (4,9) and (8,-6) provided. Participants are considering how these elements interact in the context of the problem.
Cummings
Well then i am new here and can tell i am going to spend quite some time here as well :)
I need some help with Finding Logarithmic/exponential equations from points on a graph.
In general, says my math book, you need 2 points on a graph to find 2 unknowns.
fair enough..i covered that all fine.
but now we have 3 unknowns..with 2 points and 1 asymptote
i know an asymptote is a line that the graph approaches but never meets...
i can therefore pick a point and with quite a large amount of accuracy say that that is the 3rd point
for example
say if the graph is traveling close to the asymptote, x = 3 at anything above y = 8 then i just pick a y value(above 8) and assume the x value to be 3.
and i would have a third point...i don't haveto get the answer to 100 decimal places so assuming the x value to be 3 would make quite an accurate answer.
anyways..i have uploaded the question for u to look at...its question 8
where is the problem?
Hello Cummings, and welcome to the forums
That is not totally right, it mostly depends on what variables you are talking about, and wether or not you know the family of the graph that is drawn.
Again, it depends, on the unknowns.
say if the graph is traveling close to the asymptote, x = 3 at anything above y = 8 then i just pick a y value(above 8) and assume the x value to be 3. I don't haveto get the answer to 100 decimal.
If this is everyday math, then (although i do not understand what is your problem about), yes.
But in math, you either have to take everything to be accurate, or you have to calculate the accuracy, and make sure it lies within the the range required by the problem.
I am sorry, i don't seem to be able to find the file anywhere !
Try to make your question clearer, and i am sure we will be able to answer you better.
Points aren't the only source of information.
For instance, in problem #8, you know what the asymptote of the graph is. You also know (I presume) how to find the asymptote of a logarithmic graph from its equation. You can use this knowledge in order to write one of the three equations you need to compute A, b, and c. (The other two equations come from the given points)
https://www.physicsforums.com/attachment.php?s=&postid=18189
i uploaded it before..unless u can't see it...
its question 8...
the equation is Alog[base e](x-b)+c
and i have the points (4,9) and (8,-6) and the asymptote x = 3
I need to find A, b and c
Got it.
So, 1st thing: What does the asymptote tell you?
Well, you know that ln(0)=[oo], so you can find b from that.
Next, you use the two points given to find the other two constants.
Can you try that? If you get stuck, post what you've got and we'll help.
Hurkyl, your right...
if the asymptote is at X = 3 the graph has been moved 3 units to the right... the value of b is what moves it so b must be positive and b must equal 3.
now we have eliminated b..we can use the 2 given points and the new equation y = Alog[base e](x-3)+c to find the 2 remaining points.
case closed..thanks Hurkyl.
