Calc 3: Strokes Therom Orientatio Question
  • Thread starter Thread starter Tom McCurdy
    Calc 3
The discussion centers on the application of Stokes' Theorem to a vector field F(x,y,z) = (x^2y^3z)i +(sin(xyz))j +(x^2yz)k over a cone surface S defined by y^2=x^2+z^2 between the planes y=0 and y=3. The user inquires about the parameterization of the boundary curve C, specifically why r(t) = 3sin(t) i + 3j + 3cos(t)k is used instead of r(t) = 3cos(t) i + 3j + 3sin(t)k, linking this to the positive orientation along the y-axis. The user also notes that swapping sine and cosine results in a negative integral, confirming that orientation affects the sign of the result in Stokes' Theorem.
  • Understanding of Stokes' Theorem and its applications
  • Familiarity with vector fields and line integrals
  • Knowledge of parameterization of curves in three-dimensional space
  • Basic concepts of surface integrals and orientation
  • Study the implications of curve orientation in Stokes' Theorem
  • Learn about parameterizing curves in cylindrical coordinates
  • Explore examples of Stokes' Theorem with different vector fields
  • Investigate the relationship between surface integrals and line integrals
Students and educators in multivariable calculus, particularly those focusing on vector calculus and Stokes' Theorem applications.
Tom McCurdy
[tex]F(x,y,z) = (x^2y^3z)i +(sin(xyz))j +(x^2yz)k[/tex]
S is the part of the cone [tex]y^2=x^2+z^2[/tex] that lies between the planes y = 0 and y = 3, oriented in the direction of the positive y-axis
My question deals with orientation (see below sec 3)
[tex]\int_c F dr = \int\int_S F dS[/tex]
Alright so the boundary curve C is the circle [tex]x^2 + y^2 = 9[/tex] [tex]y=3[/tex]
My question is why does r(t) become
[tex]r(t) = 3sin(t) i+ 3j + 3cos(t)k[/tex]
instead of
[tex]r(t) = 3cos(t) i+ 3j + 3sin(t)k[/tex]
I am assuming it has something to do with the positive orientation towards positive y axis
When I did the problem I got the exact negitive of what the answer should be
i got [tex]\frac{-2187}{4}\pi[/tex] instead of [tex]\frac{2187}{4}\pi[/tex]
so I was also going to ask if I mess up the cos and sin like i did on this one should I always get the opposite sign of the correct answer or was this just random?
Also should all Strokes theorms problems be positive answers?
If you swap sin and cos in your parameterization of the curve C, you will get the negative answer (provided there aren't any other curves to be integrated along) since this effectively reverses the orientation of the curve from C to -C (C traversed backward), this gives a negative answer because
[tex]\int_{-C}\vec{F}\cdot d\vec{r} = -\int_{C}\vec{F}\cdot d\vec{r}[/tex].
No, absolutely not.
