Non colinear points
by esmeco
Tags: colinear, points
esmeco
esmeco is offline
#1
Dec19-06, 03:44 PM
P: 145
The problem states the following: Show that the points of space A(3,1,-5) B(8,3,3) and C(2,1,-4) are not colinear
2. Relevant equations
I've tried to use the equation y2-y1=x2-x1 for the straight line on IR2 but since we are working in IR3 the same formula doesn't apply
3. The attempt at a solution
I'm not sure how we calculate the slope of the straight line on IR3 or if there's another formula to demonstrate that the points are non colinear.
Thanks in advance for the reply!
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
OlderDan
OlderDan is offline
#2
Dec19-06, 03:51 PM
Sci Advisor
HW Helper
P: 3,033
You could create displacement vectors from one of the points to the other two and take the dot product or cross product of the two vectors. Either way, if you know how the dot and cross products of parallel vectors behave, you can reach the needed conclusion from either one of these products.
esmeco
esmeco is offline
#3
Dec19-06, 10:20 PM
P: 145
Let me see if I understood this correctly...I should make 2 vectors out of these 3 points,lets say vector AB and vector BC.To demonstrate that the points are non-colinear, calculating the dot or cross product they must be different than zero.If vector AB and vector BC are not multiple of one another(hence not parallel), the vectors are non colinear,hence the points are non colinear.Am I right on this?Feel free to correct me if I'm wrong!Thanks in advance for the reply!
OlderDan
OlderDan is offline
#4
Dec19-06, 10:58 PM
Sci Advisor
HW Helper
P: 3,033
Non colinear points
Quote Quote by esmeco View Post
"Different than zero" would come in if you chose to use the cross product to test for colinearity, but not if you use the dot product. What must be true about the cross product of parallel vectors? How does the dot product depend on the angle between two vectors?
esmeco
esmeco is offline
#5
Dec20-06, 07:37 AM
P: 145
After searching a bit, I think I'm correct now(but again feel free to correct me if I'm wrong): The cross product of vectors must be zero,hence if it's zero their parallel,and since their parallel their colinear.Using the dot product, if the result of that product equals one, the vectors are parallel.
Am I right?
OlderDan
OlderDan is offline
#6
Dec20-06, 09:00 AM
Sci Advisor
HW Helper
P: 3,033
Am I right?
The dot product does not have to be one, but the ratio of the dot product to the product of the lengths of the individual vectors must be one if the points are colinear. The cross product will be zero if they are colinear. More generally these conditions apply to any pair of parallel vectors. They do not have to be displacement vectors formed by colinear points.
Another way to show that your points are colinear is to show that one vector is a multiple of the other. If you compare the ratios of corresponding components, all the ratios will be the same if the points are colinear.
esmeco
esmeco is offline
#7
Dec20-06, 09:17 AM
P: 145
Thank you for your help!I now understand it!
Register to reply
Related Discussions
max points, points of inflection Calculus & Beyond Homework 2
glasses to fix near points and far points Introductory Physics Homework 4
Topology (Boundary points, Interior Points, Closure, etc...) Calculus & Beyond Homework 13
colinear points? General Math 5
boiling points, melting points and absorbed radiation Q's Introductory Physics Homework 0
