Do I Need to Install Drivers for My DVD-ROM Drive?
  • Thread starter Thread starter jmnew51
The discussion revolves around the compatibility and functionality of a DVD-ROM drive in an older Windows 98 system. Participants explore whether additional drivers are necessary for the DVD-ROM to function properly, particularly in reading DVDs compared to CDs.
  • One participant, Jim, questions whether drivers need to be installed for the DVD-ROM drive since it is an older system running Windows 98, which may not have native support for DVD drives.
  • Another participant suggests that if the DVDs contain movies, third-party software with codecs, such as Power DVD, may be required to play them.
  • Jim clarifies that the DVDs contain data files (avi, mp3, jpeg) and notes that the device manager lists the DVD-ROM but identifies it as a standard CD-ROM, indicating potential driver issues.
  • One reply recommends checking the manufacturer's website for updated drivers and suggests testing the drive with different DVD formats to rule out hardware issues.
  • Another participant explains that DVDs and CDs are read using different lasers, implying that if CDs work but DVDs do not, there may be a problem with the DVD laser.
  • Jim acknowledges the possibility of having two lasers in the device and contemplates replacing the drive if it is malfunctioning.
  • A later reply reiterates that from Windows' perspective, CDs and DVDs are treated similarly, but if DVDs are not reading while CDs are, the issue likely lies with the drive itself.
Participants express differing views on whether the issue is related to driver installation or hardware failure. There is no consensus on the exact cause of the problem, and multiple potential explanations are presented.
Limitations include the lack of clarity on the specific drivers needed for the DVD-ROM and the uncertainty regarding the functionality of the laser mechanisms within the drive.
jmnew51
I have an older system running win 98 and a dvd-rom I'm trying to make work with the system. I know that when I do a clean format and install win 98 as a new OS, a cd-rom of course works because the drivers are there in the initial setup. OK now I take this dvd-rom drive and stick it in in place of the cd-rom and it seems to get stuck trying to read a dvd that I have. I've tried several different dvd's and they all do the same. It reads a regular cd very well though. Question is...do I have to install drivers for the dvd drive, as dvd players didn't get big till after win 98? And if so any ideas where I can download them from?
Thank you very much.
Jim
Computer science news on Phys.org
What kind of data is on DVD? If its a movie, you'll need a third party software with codecs to play movies. An example program would be Power DVD.
EDIT: another thing. How does windows identify your dvd drive? You can check the http://www.annoyances.org/exec/show/article01-420 ? Does it have DVD anywhere in its name or just CD? The device manager is a good place to start to troubleshoot hardware problems. You can see what drivers your dvd drive is currently using.
Just plain data is on the disc. Like avi, mp3, jpeg. I checked the device manager and the make and model # is listed. And it is referred to as a dvd-rom, but in the properties it shows up as a standard cd-rom and the driver file details button is not highlighted. BTW I found a driver for the dvd-rom on my recovery disc, but when I try to install the driver windows doesn't go thru the motions.
Jim
Since you know the make and model, you can go to the manufactures website and get updated drivers. But since windows is picking it up, I fear that there may be a problem with your laser. But to be sure that you didnt loose the laser, try different dvd formats (dvd+r, dvd-r, etc) and manufacturers. Also try the drive on a different computer (mayb different windows version) and see if it works. If you don't get anything out of that, then chances are that you've lost the (dvd) laser functionality.
Like I was saying windows reads a regular cd that I put into the dvd player rather well. So I guess the laser is OK? It just seems to have a problem with dvd's that it tries to read.
I will try the manufacterers website in the meantime.
Thanx
Jim
DVDs and CDs are read on different wavelengths. Hence two different lasers are needed.
Note the physical differences among the lasers:
http://www.blu-raydisc.com/assets/largeparagraphimage/bd_dvd_cd_laser-12755.gif
Oh I see now. I did not realize that there were actually 2 lasers in the device.
Yeah maybe it's time to chuck it and just get a new one. They're cheap enough anyway.
Thanx again
Jim
Yes, as far as windows is concerned, a cd and a dvd are the same device - the interface is identical. If a dvd isn't reading but a cd is, the problem is with the drive.
OK. Thanx very much for all the info.
Jim
11K
  • · Replies 24 ·
12K
  • · Replies 37 ·
