What are complex numbers used for
The discussion revolves around the applications of complex numbers in various fields, including physics, engineering, and mathematics. Participants explore both theoretical and practical uses of complex numbers, addressing their role in solving equations, circuit analysis, wave functions, and more.
  • Some participants note that complex numbers are useful in circuit analysis, allowing for simpler calculations in AC circuits by treating them like DC circuits.
  • Others propose viewing complex numbers in terms of magnitude and phase, which is essential for understanding wave functions and interference patterns.
  • A historical perspective is provided, indicating that the cubic formula necessitates complex numbers, even when the roots are real, highlighting a paradox regarding real numbers that cannot be expressed without complex numbers.
  • Some participants argue that complex numbers simplify the handling of differential equations, especially those involving cycles, by using complex exponentials instead of trigonometric functions.
  • There are claims about the relationship between complex numbers and physical properties, such as quantum mechanics and gauge invariance, suggesting that complex numbers play a crucial role in understanding fundamental interactions.
  • A participant challenges the idea that certain real numbers cannot be expressed without complex numbers, suggesting that there may be alternative representations using trigonometric functions.
  • Another participant expresses uncertainty about the implications of using complex numbers in algebraic representations, questioning the assumptions made in the discussion.
Participants express a range of views on the necessity and utility of complex numbers, with some agreeing on their applications while others contest specific claims regarding their role in algebraic representations and solutions. The discussion remains unresolved on certain points, particularly regarding the representation of real numbers without complex numbers.
Limitations include the dependence on definitions of algebraic and analytical solutions, as well as unresolved mathematical steps related to the cubic formula and its roots.
Hypercase
My doubt is what are complex numbers used for. Sure I can use them to solve eqns where there are no real solutions. But how does that help. What is the real life application of complex numbers.
Mathematics news on Phys.org
The first "application" I ever used them in was circuit analysis. Instead of having to solve differential equations or use Laplace transforms, you can sometimes use complex numbers instead.
So you can treat an AC circuit like a DC circuit with complex numbers for impedance, voltage, current, etc. instead of real numbers.
Think about a complex number in terms of a magnitude and phase, not as a pair of numbers in a 2-d plane. A wave function has a magnitude and a phase, if not, you'd never get constructive and destructive interference, i.e. interference patterns.
Historically, the application that forced the mathematical community to accept complex numbers was that of the cubic formula; in general it absolutely requires complex numbers to work, even when all of the roots of the cubic equation are real numbers.
In fact, there is an interesting "paradox" that there exist real numbers that cannot be written in terms of arithmetic and roots without using complex numbers.
Various applications that deal with 2-d geometry (e.g. 2-d fluid flow) can be handled in a much simpler way using complex numbers.
There are lots of problems about real numbers that can be done in a simpler way by using complex numbers. e.g.
[tex] \begin{equation*}\begin{split}<br /> \int e^x cos x \, dx &= \int \Re ( e^x (\cos x + i \sin x) )\, dx \\<br /> &= \Re \int e^{x + ix} \, dx \\<br /> &= \Re \int e^{(1+i) x} \, dx \\<br /> &= \Re \left( \frac{1}{1+i} e^{(1+i)x} + C \right) \\<br /> &= \Re \left( \frac{1}{2} (1 - i) e^x (\cos x + i \sin x) + C \right) \\<br /> &= \frac{1}{2} e^x (\cos x + \sin x) + C<br /> \end{split}\end{equation*}[/tex]
In summary, if they weren't useful, we wouldn't use them. :smile:
They can be used to simplify the way you obtain many results.
In many applications (physics, economics, engineering), you end up with differential equations involving cycles, which can be expressed in terms of sines and cosines. Instead, you can use complex exponentials to encode the same information. Why would you want to do that? because exponentials behave much nicer under integration and differentiation.
Also, since complex numbers are so closely related with rotations, they are perfect to represent many physical properties were analogous symmetries are involved. When you get to quantum mechanics, you find a property called "spin" (which is NOT physical rotation), the behavior of which is very similar to how imaginary numbers combine. when you combine the matrices that describe this property, you get i's all over.
At a deeper level, it turns out that a strong connection can be established between the electromagnetic field and quantum mechanics via something called "gauge invariance". In a nutshell, if you require that the Schrödinger equation give the same solution regardless of the complex phase of your wavefunction, you end up needing the EM field.
One more: the electoweak interaction has, as symmetry group (which is closely related to how it behaves), the same as that of complex numbers (U(1)).
Yet another: have you heard of CP-violation? it is basically the fact that matter and antimatter behave differently (which is quite surprising, since they are essentially mirror images of each other). CP-violation can be understood and quantified in terms of a complex phase in a matrix that relates the different types of quarks.
Wow! Can you expand on that? (or provide a link)
If Hurkyl will forgive my jumping in here: there was a problem in another thread that reduced to solving the cubic equation 8x3- 6x= 1.
It's easy to show that that has 3 real roots (y= 8x3- 6x- 1 is negative for x< -1, positive for x= -0.5, negative again for x= 0, and positive for x=1- there must be one root between -1 and -0.5, another between -0.5 and 0, and a third root between 0 and 1.
The "cubic formula" gives that positive root as ((1+sqrt(3)i)/16)1/3+ ((-1+ sqrt(3)i)/16)1/3.
Even though that root is a positive real number, there is no way to represent it exactly without using a complex number.
Not sure how much I buy that.
There is anyway in implicit assumption that one means 'describe algebraically' in this thread, obviously 'analytically' is different.
I think the reason I don't buy this example is that there might be a solution for this polynomial in terms of trig functions. In fact a quick check tells me there is since
4(-6/8)^3 + 27/64 is negative.
Moreover, using Cardano's formula yields things like:
[tex](2+i11)^{1/3}+(2-i11)^{1/3}[/tex] which is actually equal to 4 (for some choice of cube root).
edit. I also presume you mean in terms of extracting roots etc of rational numbers - there is not problem with defining {a,b,c} to be the three roots of the cubic in ascending order. And what about transcendental numbers too?
Oh sure, make me remember my algebra. I haven't been able to recall/devise a proof in a few hours, and I can't think where to look for a reference. I'll ask at work later this week to see if anyone knows.
Well, I found a reference, sort of...
http://library.wolfram.com/examples/quintic/timeline.html
1890, 1891
Vincenzo Mollame (1848-1912) and Ludwig Otto Hoelder (1859-1937) prove the impossibility of avoiding intermediate complex numbers in expressing the three roots of a cubic when they are all real.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 18 ·
