Lipschitz Continuity and measure theory
The discussion revolves around Lipschitz continuity and measure theory, specifically addressing the properties of a bounded and measurable function defined on the interval [0, ∞). Participants explore two parts of a problem involving the function F defined as the integral of f, discussing implications for continuity and measure of sets.
  • One participant proposes to rewrite the set E as an infinite disjoint union of open/closed sets, but another notes this may not be useful in all cases, citing the Cantor set as an example.
  • Some participants suggest considering simpler cases, such as when f is continuous and E is a "sufficiently nice" set, which may allow for differentiability of F.
  • There is a discussion about whether F is always differentiable, with one participant clarifying that F is almost everywhere differentiable.
  • Another participant suggests starting the proof with an open interval and then extending it to open sets and arbitrary measurable sets.
  • One participant describes a method to prove the result for countable unions of disjoint open intervals and subsequently for Gδ sets, concluding that it should hold for any measurable set.
  • Clarifications are made regarding the positive and negative parts of the function f, and how they relate to the bounds M+ and M- used in the proof.
Participants express various viewpoints and approaches to the problem, with no clear consensus reached on the best method to tackle the second part of the problem. Some agree on certain properties of F and the implications for measure theory, while others raise questions and propose alternative methods.
Participants note limitations regarding the assumptions made about the function f and the nature of the set E, particularly in relation to continuity and differentiability. The discussion reflects a range of mathematical reasoning without resolving all uncertainties.
This discussion may be useful for those interested in measure theory, Lipschitz continuity, and the properties of integrable functions, particularly in the context of mathematical analysis and advanced calculus.
bham10246
Hi, this is not a homework problem because as you can see, all schools are closed for the winter break. But I'm currently working on a problem and I'm not sure how to begin to attack it. Here's the entire problem:
Let f be bounded and measurable function on [0,00). For x greater than or equal to 0, define F(x)= \int_{0,...,x} f(t)dt.
Part i. Show that there is some positive M such that |F(x)-F(y)| <= M|x-y|.
Part ii. Prove that there exist a constant C such that m(F(E)) <= C(m(E)) for every Lebesgue measurable set E of [0,00). Note that m(E) is the Lebesgue measure of the set E and F(E) := {F(x) : x is in E}.
I know how to do Part i. But as for Part ii., I'm not sure how to begin working on it. Can I rewrite E as an infinite disjoint union of open/closed sets??
Note that 00 means infinity and <= means less than or equal to.
Thank you.
Yes, but not in a useful way. For example, the Cantor set requires an uncountable union.
I don't see the proof immediately, but I can see how to do a simpler case. What if f is continuous, and E sufficiently nice? (And, thus, F is differentiable) Remember that [itex]m(S) = \int_S 1 \, dx[/itex].
Thanks Hurkyl. I forgot about the Cantor set. I'll think about it some more but I still don't see it.
We have to find C so that the above inequality works, and I think we're supposed to use Part i.
Hmm... maybe if we begin by assuming that E is an open set, then |F(x)-F(y)| <= m(F(E))? At this moment I'm not sure how m(E) fits in with m(F(E)).
Also, whether f is continuous or not, F is absolutely continuous. So F is always differentiable, isn't it?
F is almost everywhere differentiable, IIRC. (but not necessarily everywhere differentiable)
The starting point that I'm imagining is that
[tex]\int_{F(E)} 1 \, dx = \int_E f(x) \, dx.[/tex]
But that doesn't work in the most general case.
I think you see something similar; did you mean to say that you're assuming E to be the interval (y, x)? In that case, m(E) = |x - y|, which is how you can get the desired relationship.
Start by proving it for an open interval, then an open set, then an arbitrary measurable set.
If it holds for E an open interval, then it holds for E a countable union of disjoint open intervals by subadditivity:
[tex]m(F(\cup E_i)) = m(\cup F(E_i)) \leq \sum mF(E_i) \leq \sum Cm(E_i) = C\sum m(E_i) = cm(E)[/tex]
Thus it holds for any open set. Thus it holds for any countable intersection of nested open sets, since:
[tex]m(F(\cap U_i)) \leq m(\cap F(U_i)) = \mbox{inf} mF(U_i) \leq \mbox{inf} Cm(U_i) = C\mbox{inf} m(U_i) = Cm(\cap U_i)[/tex]
Thus it holds for any [itex]G_{\delta}[/itex] set. But every measurable set is just a [itex]G_{\delta}[/itex] set unioned with a zero set, so it should hold for any measurable set.
To get the result to hold on an open interval, separate f into its positive and negative parts, and you should get:
[tex]m(F((x,y)) \leq \int _x^yf^+(t)dt + \int _x^yf^-(t)dt = |F^+(y) - F^+(x)| + |F^-(y) - F^-(x)| \leq M^+|x-y| + M^-|x-y| = (M^+ + M^-)m((x,y))[/tex]
To clarify, the positive part of f is f+, which is defined as follows: f+(x) = f(x) when f(x) is positive, and f+(x) = 0 when f(x) is negative. [itex]F^+(x) = \int _0 ^x f^+(t)dt[/itex]. Clearly, the positive and negative parts of f are bounded and measurable, so part i applies to them, and it is by applying part i to these to functions that we get M+ and M- (you might have been wondering where those numbers came from).
Note, the first inequality in the last line might need some explanation, but you should be able to get it for yourself. Unfortunately, I don't have time now to elaborate.
Thanks so much! I think I can go from here. Actually, I thought about it on my way out and I figured it out. Thanks so much everyone!
