Thread Closed
Square Root of Complex Numbers
Share Thread Thread Tools
Dec25-06, 01:34 PM   #1
Hi! I've got a question.
There is a nice formula for finding square roots of arbitrary complex numbers z=a+bi:
[latex]\frac{1}{\sqrt{2}}(\epsilon\sqrt{|z|+a}+i\sqrt{|z|-a})[/latex] where
epsilon:=sing(b) if b≠0 or epsilon:=1 if b=0.
I've just looked it up and it's nice to use it to find complex roots of quadratic equations with complex coefficients.
Where does it come from? I mean, squaring shows that it's true but how can one derive it from other facts? Is there a similar formula for n-th roots (not in polar form but analogous to that above)? Any info, links?
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Dec26-06, 09:45 PM   #2
LittileHilbrt;
Let y=c+id, where y^2=z.
Then; c^2-d^2+2i c*d=a+ib.
As a result; a=c^2-d^2 (eq1) and b=2c*d (eq2).
Therefore, from eq1 and eq2; c^2 = a + (b/c)^2/4 (eq3);
Solving eq3 in c^2, we get c^2={a+sqr(a^2+b^2)}^.5 /2
Therefore, c=(+/-) sqr({a+mod(z)}/2) (eq4 ),
{the other solution is rejected as c must be real}.
Then; z^1/2 = (+/-) y = (+/-) [c + id] = (+/-) [c+id] = (+/-) [sqr({a+mod(z)})+i sign(b)* sqr({[mod(z)]^2 –a^2} / {a+mod(z)})]/sqr(2)
= (+/-) [ sqr( a+mod(z) ) + i sign(b) * sqr({mod(z)–a} ] / sqr(2)
= (+/-) [sign(b) * sqr( a+mod(z) ) + i sqr({mod(z)–a} ] / [sqr(2)* sign(b)]
====> (+/-) [sign(b) * sqr( a+mod(z) ) + i sqr({mod(z)–a} ] / [sqr(2)]
Solving these equaitons when b=0 will need some modifications. By the way, when b is zero, z is real.
Amr Morsi.
Dec26-06, 10:59 PM   #3
It can probably be derived with few identities and Demoivre's theorem.
Dec26-06, 11:19 PM   #4
Recognitions:
Homework Helper Homework Help
You could always convert the number to e^(x + iy) form, divide x and y by 2, convert back to normal form. I think that should work.
Dec27-06, 02:23 PM   #5
Recognitions:
Quote by littleHilbert View Post
littleHilbert,
When you multiply by a complex number, you are rotating the other number
by the angle the complex number makes with the x-axis.
For example, multiplication by "i" makes a rotation of 90 degrees. Therefore
a multiplication by the square of "i" makes a rotation of 180 degrees or -1.
Hence "i" is the square root of -1.
If you want the "n-th root" of a number; express it in polar form, and
divide the angle by "n". You will get the polar expression for the n-th
root. Use trigonometric identities to transform back into the non-polar
form in terms of the components of the original complex number.
Normalize appropriately if the modulus of the number is not unity.
That's how the formula you cite above is derived.
Dr. Gregory Greenman
Physicist
Dec27-06, 04:41 PM   #6
the question is..take the identity:
[tex] (\sqrt (-2)+1)(\sqrt (-2)-1)=-2 [/tex] and expand it by a continous fraction..what would we get..
Thread Closed
Thread Tools
Similar Threads for: Square Root of Complex Numbers
Thread Forum Replies
Yes or no, Can you square root a zero Precalculus Mathematics Homework 11
Complex Variables. Complex square root function Calculus & Beyond Homework 0
Square of complex numbers Precalculus Mathematics Homework 14
complex contour integral of square-root Calculus & Beyond Homework 1
Sq root of complex numbers Precalculus Mathematics Homework 3
