How Does Wheel Size Affect the Force Needed in Motorcycle Thrust?
  • Thread starter Thread starter Ascetic Anchorite
    Force Wheel
The discussion revolves around the relationship between wheel size and the force required for thrust in motorcycles and bicycles. Participants explore how different gear sizes and wheel radii affect the force needed to achieve certain speeds against resistive forces like drag and rolling resistance.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the mechanics of force and torque in relation to wheel size and gear ratios. Questions arise regarding the implications of larger wheels and cogs on performance and efficiency, as well as the assumptions made in existing reports on rolling resistance.
Some participants have provided clarifications on the mechanics involved, particularly regarding torque and force relationships. There is an ongoing exploration of the implications of gear sizes and wheel dimensions, with no explicit consensus reached on the advantages of different setups.
Participants note that practical factors, such as the size of the driver cog and the effects of larger cogs on performance, complicate the theoretical advantages discussed. Additionally, there is mention of varying reports on rolling resistance that do not address mechanical advantages related to gear and wheel sizes.
Ascetic Anchorite
I am sure this is a simple problem, but I am posting this thread to make sure I understand it properly:
If a motorcycle requires 3000N of force in order for it to achieve a certain speed over specific terrain and allowing for wind drag, etc. (I.E to counter the sum of the resistive forces acting against it), then it will need 3000N of thrust. This could be accomplished by an immensely strong person pushing the motorcycle or by a shaft and bevel drive connected to one of the wheels creating 3000N of ‘push’ where the tyre contacts the ground (directly below the axel).
However, if the wheel has a radius that is three times that of the bevel cog (the cog attached to the wheel and driven by the drive shaft) then in order for the wheel to have 3000N of push against the ground (road surface) the shaft drive would need to input three times this 3000N into the cog. E.g. if the cog, that is directly mounted to the center of the wheel, has a radius of 0.1m and the wheel, that is three times larger, has a radius of 0.3m then the drive shaft should exert a force of 9000N upon the cog in order to achieve the required 3000N of thrust at the ground/tyre contact point.
Is this correct?
Yes, that sounds correct. You can think about it in terms of torques. 1/3 the lever arm requires 3x the force in order to produce the same torque. The sum of all forces and torques on an object must equal zero if it is not accelerating linearly or rotationally.
Many thanks for your clarification.
I have just been thinking about this; if a racing cyclist had a rear cog the same size as the wheel to which it is attached then the cyclist would be able to transmit more force into the wheel and thus be able to go faster. Of course, in practice, there are other factors that get in the way, such as the size of the driver cog (attached to the cranks), effects of having such a large cog on a wheel, etc., but if these can be overcome then, in theory, a cyclist could transmit several times the power that they currently transmit using standard gear setups.
This must be why many advocates of small-wheeled bicycles claim their bikes to be faster and more efficient than conventionally wheeled bikes. The reports I have read talk only of effects of rolling resistance of various wheel sizes, concluding that smaller wheels fare better (although many others claim that larger wheels endure lesser effects of rolling resistance). The authors of these reports said nothing of mechanical advantage, or disadvantage, concerning the respective sizes of the driven wheel and cog/sprocket.
I find that to be rather odd.
Road racing bicycles have gear ranges that allow the rider to target the most efficient cadence for the conditions. It is no help to put more power to the ground if you can only sustain that power output for a brief period.
  • · Replies 16 ·
  • · Replies 35 ·
10K
