Register to reply
Relative factor, what does the number 1 stand for?
by disregardthat
Tags: factor, number, relative, stand
Share this thread:
disregardthat
#1
Dec26-06, 01:06 PM
Sci Advisor
P: 1,807
ok i don't know how to use this forums equation pictures so i'll just add a picture of the equation.
And I am not that good in this, I don't have education abour physics or math in this way.
This equation is the relativity factor equation and equals the relative factor right? Anyway, I was wondering what the number "1" at the top of the bracket stood for? I have seen people replace it with for example 2(pi)r. what does it stand for, and what does it mean, and what does it mean when it is 1.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Doc Al
#2
Dec26-06, 01:09 PM
Mentor
Doc Al's Avatar
P: 41,477
Quote Quote by Jarle View Post
Sure, usually called "gamma".
It's the numerator of that fraction. In the fraction 1/2, what does the 1 stand for? Same answer.
Mindscrape
#3
Dec26-06, 11:21 PM
P: 1,874
I don't think he asked what the 1 in the numerator was for. I think he was asking why the factor is inversely proportional rather than proportional. This factor, which as Doc Al said is usually denoted by "gamma," was developed by Lorrentz as an answer to the failed idea of the luminiferous aether (that light is carried by some sort of light wind). Lorrentz deduced the factor from the Michelson-Morely interferometry experiments (extra info) in order to formulate his modified aether postulate, which Einstein later showed to be wrong - but the factor of gamma still worked. You could look up the derivation if you are interested.
As far as the 2*pi*r goes, you must be taking it out of context. Maybe it was describing some kind of one dimensional general relativity, which is much different from special relativity..
disregardthat
#4
Dec27-06, 04:56 PM
Sci Advisor
P: 1,807
Ah, thanks I understand it now. The only thing i'm not quite sure of is that when we use a velocity, is that the number of the meters between the observer and object per second?
If one travels in 200 000 km\s one way, and another 200 000 km\s in the opposite direction. Each of these travellers would surely not measure the other to go in 400 000 km\s, even though a third observer would see both go in 200 000 km\s in the respective directions.
So, the velocity we are putting in is the velocity one observer measure an object moving. How do we measure the space that is laid between them each second?
turdferguson
#5
Dec27-06, 05:11 PM
P: 312
Well that specific equation is used for time dilation and length contraction. A similar equation is used for relative velocities (you cant just add vectors as you suspected) Check this out:
http://en.wikipedia.org/wiki/Relative_velocity
disregardthat
#6
Dec27-06, 05:50 PM
Sci Advisor
P: 1,807
Quote Quote by turdferguson View Post
And mass!
I did not understand which of the equations you had to use... If it has more factors than v and c you must tell me what the letters stand for, if you want.
turdferguson
#7
Dec27-06, 06:21 PM
P: 312
And mass!
w and v are the respective velocities of the two objects. Normally, you could just subtract vectors (the numerator of the equation). Keep in mind that if theyre approaching each other as you said, their signs are opposite and youre actually adding. But with relativistic speeds, the rules start to break down and you need a familiar-looking denominator.
D H
#8
Dec27-06, 06:32 PM
Mentor
P: 15,170
Quote Quote by Mindscrape View Post
AFAIK, Lorentz Ether Theory (LET) and Special Relativity (SR) are identical in outcome. SR did not "win the day" because SR predicts some observed outcome not predicted by LET (they predict identical results). Rather, SR became the dominant theory because of its elegance and simplicity. Lorentz-Fitzgerald contraction is derived in SR and merely axiomatic in LET.
And mass!
Not mass! That is an archaic view. The equations come out the same if you whether you factor the Lorentz factor into the mass or leave it as-is. If you do factor the Lorentz factor into the mass, the mass varies with direction. Yech.
Mindscrape
#9
Dec27-06, 06:42 PM
P: 1,874
I don't really know anything about the Lorentz Ether Theory. Originally special relativity became accepted because of it's elegance, but now doesn't LET come into conflict with field theory?
disregardthat
#10
Dec27-06, 07:59 PM
Sci Advisor
P: 1,807
Thanks for the equation.
Why not mass? The http://www.1728.com/reltivty.htm Relativity calculator says that the mass is multiplied with the relative factor.
And what is the lorentz ether theory?
D H
#11
Dec27-06, 08:46 PM
Mentor
P: 15,170
Jarle, I strongly urge you not to study physics by means of memorizing equations (which is what you appear to be doing) without knowing the theory behind them.
Why not mass? Because relativistic mass leads to an ugly mess. The relativistic mass varies with the direction a force is applied.
Here are Einstein's own words on relativistic mass:
From a letter by Einstein to Lincoln Barnett written in 1948:
It is not good to introduce the concept of the mass [itex]M = m/\sqrt{1-v^2/c^2}[/itex] of a body for which no clear definition can be given. It is better to introduce no other mass than `the rest mass' m. Instead of introducing M, it is better to mention the expression for the momentum and energy of a body in motion.
Lorentz Ether Theory (LET) was a precursor to Special Relativity. The Lorentz-Fitzgerald contraction was an axiomatic attempt to explain away the null results of the Michelson-Morley experiment while retaining some remnant of the aether. There is an absolute reference frame in LET. However, the Lorentz-Fitzgerald contraction makes it impossible to detect the aether or the absolute reference frame. Experimental physicists like to measure things to validate or disprove a theory. LET postulated an aether that experimentalists could never detect. What value is a theory in physics that is based on something that is inherently undetectable?
disregardthat
#12
Dec28-06, 05:42 AM
Sci Advisor
P: 1,807
Well, so it is not really the mass that is rising, it's the momentum? Why does it say 'm' then in the equation. And is there are place where I can read about the theory behind the equations?
Register to reply
Related Discussions
What does c-number stand for? General Physics 7
Q factor (Quality Factor) Introductory Physics Homework 2
Take a Stand Against Fur. General Discussion 42
What does the big F stand for? Calculus 10
Friction factor on very very low reynolds number Mechanical Engineering 6
