Solving Compton Scattering Homework Statement
The problem involves the Compton scattering of a photon by a relativistic electron, focusing on the conservation of energy and momentum. The original poster presents equations relating the energies and momenta of the electron and photon, aiming to derive a specific relationship involving the scattering angle.
  • Mixed
  • Participants discuss the conservation of momentum and energy, with attempts to rearrange equations to match the required form. There are questions about the placement of cosine terms and the proper handling of square roots in the equations.
Some participants have identified potential mistakes in the algebraic manipulation of the equations. There is ongoing exploration of how to correctly apply the conservation laws and the implications of treating momenta as vectors. Guidance has been offered regarding the need to square terms appropriately and to consider the vector nature of momentum.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the relationships between the variables rather than simply arriving at a solution.
Brewer
The energy E and momentum P of a relativistic electron and energy ε and momentum p of a photon are related by:
[tex]E^2 - P^2c^2 = m_{e}^2c^4 and \epsilon = pc[/tex]
let [tex]E_{i}, P_{i} and E_{f}, P_{f}[/tex] denote the inital and final energies and momenta of the electron, and let [tex]\epsilon_{i}, p_{i} and \epsilon_{f}, p_{f}[/tex] denote the initial and final energies and momenta of the photon. Assume the electron is initially at rest, so that [tex]E_{i} = m_{e}c^2[/tex] and [tex]P_{i} = 0[/tex], and assume that the photon is scattered through the angle [tex]\theta[/tex].
By considering the conservation of momentum show that:
[tex]\epsilon_{i}^2 - 2\epsilon_{i}\epsilon_{f}cos\theta + \epsilon_{f}^2 = E_{f}^2 - m_{e}^2c^4[/tex]
momentum before = momentum after
initial momentum = [tex]P_{i} + p_{i} = \frac{\epsilon_{i}}{c}[/tex]
final momentum = [tex]P_{f} + p_{f} = \sqrt{\frac{E_{f}^2-m_{e}^2c^4}{c^2}} + \frac{\epsilon_{f}}{ccos\theta}[/tex]
therefore: [tex]\frac{\epsilon_{i}}{c} = \sqrt{\frac{E_{f}^2-m_{e}^2c^4}{c^2}} + \frac{\epsilon_{f}}{ccos\theta}[/tex]
After a bit of rearranging I can get to:
[tex]\epsilon_{i}^2 - \frac{\epsilon_{f}^2}{cos^2\theta} = E_{f}^2 - m_{e}^2c^4[/tex], where the RHS is as required, but I can't rearrange the LHS to get what they want. I get the feeling I may have left a cosθ out somewhere, or that I've forgotten quite an important (yet simple) technique in here somewhere, to rearrange the LHS. I can see that it could be written as the difference of 2 squares, but I cannot see how that would help me.
Any hints appreciated.
I can directly see a mistake in the way you got rid off the square root in :
you need to do SQUARE THIS :
[tex]\frac{\epsilon_{i}}{c} - \frac{\epsilon_{f}}{ccos\theta}= \sqrt{\frac{E_{f}^2-m_{e}^2c^4}{c^2}}[/tex]
But still, there is something wrong with the position of the cosine.
marlon
edit : beware, i did not check the entire algebra or the application of the conservation laws. I just denoted an obvious mistake :)
marlon
Oh, ok so I can't just square all the terms then? I'll give it a go and see what happens.
Yes you can, only you need to do it correctly :)
you did (A+B)²=C² --> A² + B² = C²
This is, ofcourse, wrong
marlon
So the cos is in the wrong place? Well I'll work through and see where it should go. On the top of the fraction maybe?
Remember that the initial and final momenta are vectors.
Let's start all over.
1) apply conservation of energy
2) apply conservation of momentum
From 1) write that equation as [tex](P_f c)^2[/tex] =
From 2) we get : [tex]\vec {P_f} = \vec {p_i} - \vec {p_f}[/tex]
The trick is to write 2) as [tex](P_f c)^2[/tex] = ; so that we can get rid off the electron parameters [tex](P_f c)^2[/tex] . To do that (AND THIS IS WHERE YOU MADE YOUR MISTAKE WITH THE COSINE) you need to be aware of the fact that the momenta are VECTORS.
So [tex](P_f c)^2 = c^2 \vec{P_f} \cdot \vec{P_f} = c^2 ( \vec {p_i} - \vec {p_f}) \cdot (\vec {p_i} - \vec {p_f})[/tex]
THIS IS A SCALAR PRODUCT !
marlon
  • · Replies 20 ·
