Number of circles within a circle
  • Context: High School
  • Thread starter Thread starter Rade
    Circle Circles
The discussion revolves around the question of whether there are an infinite number of circles that can fit within a larger circle, considering various interpretations of the problem. Participants explore the implications of radii, the nature of circles, and the mathematical concepts involved.
  • Some participants propose that since there are an infinite number of radii within a circle, there should also be an infinite number of circles within it.
  • Others argue that the question is analogous to the existence of an infinite number of points on the number line between 0 and 1, questioning if the circular aspect introduces any special considerations.
  • Some participants suggest that if circles are defined as having no width, then an infinite number could theoretically fit within a larger circle.
  • There are claims that if circles have a nonzero area, only finitely many can fit within the larger circle without overlapping, due to the finite area of the larger circle.
  • A later reply clarifies that there is indeed an infinite number of distinct circles corresponding to every real number between 0 and the outer radius, provided the circles have no width.
  • Participants discuss the mathematical definitions of disks and circles, emphasizing the conditions under which the infinite quantity of circles can be considered valid.
Participants express differing views on the conditions under which an infinite number of circles can exist within a larger circle. Some agree on the concept of circles having no width leading to an infinite quantity, while others challenge this by introducing the idea of circles with nonzero area, leading to a lack of consensus.
Limitations in the discussion include varying interpretations of what constitutes a circle, the implications of having width versus no width, and the mathematical definitions of circles and disks. These factors contribute to the complexity of the question and the lack of resolution.
Rade
There are an infinite number of radii within any given circle, are there also an infinite number of circles within a circle as shown in the attached image ?
Mathematics news on Phys.org
Given a radius R, there is an infinite number of 0 < r < R, so the answer is yes. I can't see the attachment though, but there is no way to display that. Non-formally speaking, you could be talking about a shaded disk of radius R, I guess. :biggrin:
Seems like an analogous question to "Are there an infinite number of discrete points between 0 and 1 on the number line?" Is there something special about the circle aspect of this question?
I can see the attachment fine--are you still having problem ?
:confused: Don't know, that is why I ask. Consider that 0 and 1 that serve as limits in your example are similar limits in that they are both integers, but in the circle example it is not clear to me that both limits are similar.
It takes an average of a few minutes for the Staff and Mentors to see that there is an attachment awaiting approval. Once I saw it and approved it, everybody can see it. radou just viewed your post before I approved it.
And about the number line thing -- are you familiar with how limits work in a finite section of the number line? A related topic would be Zeno's (sp?) paradox, for example.
BTW, is this a homework problem? We should move it to the homework forums if it is.
There are an infinite number of circles if the perimeter has "no" width and the distances between the radii are zero. ie A Shaded Disk.
No it is not.
Neither of these constraints apply--see the figure in post #1--perimeter has width, not a shaded disk.
I'm not entirely sure what you're saying, but if each of the 'circles' is actually an object with nonzero area (say, the set of all points within 0.001 units of a circle) then only finitely many can fit into the (large) circle without overlapping, since the area of a circle is finite.
Well yes, that's why there isn't an infinite number of circles...
CRGreatHouse- The circles I specify for an infinite amount are not existent, just mathematical with the area between the circles zero.
OK, but there would be an infinite number if the perimeter of added circles "has no width"--in the same way that there are an infinite number of radii (without width) in a circle--correct ?
Yes, certainly. There's a circle for every real number between 0 and the outer radius.
A disk of some radius R≥0 can be thought of as {(x,y) : 0≤x2+y2≤R2}
A circle with a radius r≥0 can be thought of as {(x,y) : x2+y2=r2}
As you can see,
[tex]\left\{ {\left( {x,y} \right):x^2 + y^2 = r^2 } \right\} \subset \left\{ {\left( {x,y} \right):0 \leqslant x^2 + y^2 \leqslant R^2 } \right\}{\text{ if }}0 \leqslant r \leqslant R[/tex]
If R>0, there is an infinite quantity of distinct r that satisfy 0≤r≤R;
thus, there is an infinite quantity of distinct circles within a disk of radius R>0.
Bomba923--thank you very much for the time and clarity of your answer--what I would expect from the mathematics section of this forum.
  • · Replies 22 ·
