How Do You Calculate the Time and Distance of a Crate in Freefall from a Plane?
  • Thread starter Thread starter Mr Matt
    Forces
The problem involves a crate falling from a cargo plane flying horizontally at an altitude of 13.9 km. The crate's motion is analyzed under the influence of gravity, with specific questions regarding the time it takes to hit the ground, the horizontal distance traveled, and the distance from the plane when the crate lands.
  • Participants discuss using equations of motion to determine the time of fall and horizontal distance. There is uncertainty about which equations to apply for vertical and horizontal components, and whether the initial horizontal velocity is indeed 508 km/hr.
Some participants have suggested using the vertical motion equations to find the time of fall, while others are exploring the implications of the initial horizontal velocity. There is ongoing confusion regarding how to approach the third question and its relation to the other variables.
Participants are working within the constraints of the problem's setup, including the assumption of constant horizontal velocity and the need to calculate distances based on the time of fall. There is acknowledgment of the need for clarity on the relationships between the variables involved.
Mr Matt
A cargo plane flying horizontally at an altitude of 13.9 km with a constant speed of 508 km/hr when a large crate slides out of the rear of the plane
Assume the acceleration of gravity is 9.81 meters/seconds squared.
1)How long does it take for the crate to hit the ground?
2)What is the horizontal distance of the crate from the point it fell off to the point where it hits the ground?
3)How far is the crate from the airplane when the crate hits the ground assuming the plane remains at a constant speed?
The golden three:
Vf = Vi + (A)(T)
Vf^2 = Vi^2 + 2(A)(D)
D = (Vi)(T) + 1/2(A)(T^2)
(sorry i don't know how to do the squared simbol)
First, I drew a diagram of what is described in the problem. We were also talk to make a chart and fill in the values. Once i know what the values are for the charts, i will be able to solve the problem(it is multiple parts). I only need help in solving the values for the charts. The chart is as follows:
Vertical(y)__________Horizontal(x)
Vi- 0 ______________Vx- ?
Vf- ? ______________Dx- ?
A-(-9.8m/s)_________T-?
D- 13.9km
T-?
I know that time is constant on both, and i think i have all the given info in the charts, but i don't really know what to do after this. Please, if anyone could help that would be great, thanks
How about using equation number 3 to solve for time using the vertical components.
You have said that vi in the y direction is 0. Does this tell you anything about vi in the x direction?
But i don't know if you use the vertical or horizontal equations, and I think Vx might be 508 km/hr, but its just a guess. Can anyone confirm this?
Like I said above, use your third equation in the vertical direction to solve for t.
vi in the x direction = 508 km/h. Note that you should have vi and vf in the x direction, like in the y direction, not just one term vx.
I suggest you use obtain t in the y direction, and then you should be able to solve the other problems using this t (since equal time will be taken for the crate to fall in both the x and y directions).
kk thanks a lot
But then how would u solve for the third question? The third question isn't a variable in one of the following equations right? I'm so confused :(
Presume the plane traveling at constant horizontal velocity. You know the time the crate hits the ground, so calculate the distance the plane travels in this amount of time. Subtract from this the distance from the intial point that the crate hits the ground.
  • · Replies 17 ·
