Register to reply
Black body radiation problem
by Amith2006
Tags: black, body, radiation
Share this thread:
Amith2006
#1
Dec30-06, 03:18 PM
P: 421
1)The peak emission from a black body at a certain temperature occurs at a wavelength of 9000 Angstrom. On increasing its temperature the total radiation emitted is increased 81 times. At the initial temperature, when the peak radiation from the black body is incident on a metal surface, it does not cause any photoemission from the surface. After the increase of temperature, the peak radiation from the black body causes photoemission. To bring these photo electrons to rest, a potential equivalent to the excitation energy between n=2 and n=3 Bohr levels of Hydrogen atom is required. Find the work function of the metal.
2. Relevant equations
According to Weinís displacement law,
[lambda1(max.) x T1] = 2.898 x 10^(-3) metre-Kelvin
According to Stefanís law,
Energy of incident radiation(E2) = (sigma) x T^4
3. The attempt at a solution
I have doubt only in the first part of the problem. So I havenít worked out the entire problem.
I solved it in the following way:
Let T1 and T2 be the initial and final temperatures respectively. Let lambda1(max.) and lambda2(max.) be the initial and final wavelengths respectively. Let E1 and E2 be the initial and final energy of the radiations respectively.
E is proportional to T^4
Hence,
E1/E2 = [T1/T2]^4
Therefore,
T2 = 3T1 {since given that E2/E1 = 81}
Hence, T1 = 3220 Kelvin
Hence, T2 = 3T1 = 9660 Kelvin
= 5.67 x 10^(-8) x (9660 x 10^(-10))^4
= 4.94 x 10^(-32) Joules
The solution given in my book is as follows:
Hence,
E1/E2 = [T1/T2]^4
Therefore,
[lambda(max.) x T] = constant
i.e. [lambda1(max.) x T1] = [lambda2(max.) x T2]
lambda2(max.) = 3000 Angstrom
Energy of incident radiation(E2) = hc/ lambda2(max.) = 6.63 x 10^(-19) Joules
Why do I get 2 different answers?
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
Mindscrape
#2
Dec30-06, 11:43 PM
P: 1,874
You assumed a lot of things when you use Stefan's Law: that it was a perfect blackbody, and the flux was uniform.
The solution your book gave is correct because it does everything through Wein's Law, and then uses the fact that E=hv=hc/lambda.
Amith2006
#3
Dec31-06, 01:58 AM
P: 421
Thats cool! Thanks.
Register to reply
Related Discussions
Black body radiation Cosmology 0
Black Body Radiation Classical Physics 2
Black body radiation Quantum Physics 5
Black body Radiation Introductory Physics Homework 2
Black body radiation Quantum Physics 2
