How Can I Connect Multiple Modules in Verilog?
  • Thread starter Thread starter david90
    Language
The discussion revolves around connecting multiple modules in Verilog, specifically how to instantiate and wire them together in a top-level module. Participants explore the mechanics of module interconnection, including the use of wires and the integration of outputs into logical operations like AND gates.
  • Homework-related
  • One participant asks how to connect three modules in Verilog so that the output of one feeds into another.
  • Another participant suggests creating a top-level module that instantiates the three modules and connects them with wires.
  • A participant seeks clarification on the term "instantiates" and requests more detail on how to use wires for connections.
  • A participant provides an example of a top-level module that connects two sub-modules using the "wire" keyword.
  • There is a confirmation that the input of one sub-module is wired to the output of another, though the naming in the example is noted as potentially confusing.
  • A participant presents a new problem involving connecting three module outputs to an AND gate and asks for guidance on this setup.
  • Another participant provides a snippet showing how to connect outputs to an AND gate using wires.
  • A participant inquires about linking four one-bit ALUs to create a four-bit ALU, questioning if the same method applies.
  • A participant confirms that the same method can be used but advises caution regarding carry signals.
Participants generally agree on the method of using a top-level module and wires to connect sub-modules, but there are varying levels of understanding and requests for clarification on specific terms and implementations.
Some participants express uncertainty about terminology and specific implementation details, indicating a need for further clarification on wiring and module instantiation.
david90
Say I have 3 modules and I want them to connect them together (make them work together. Ie, output of one module would go into another etc.), how would I do this in verilog?
Create a top-level module that instantiates each of the three modules, and connects them with wires.
- Warren
instantiates ?[?] [b(] U mean create a 4th module that connects the 3 modules together with wire? Can u elaborate on the "wire" part?
Yes, make a top level module which creates instances of the three lower modules.
The "wire" keyword, surprisingly, makes wires.
Here's a simple example with two modules, sub_a and sub_b, and a toplevel module which connects their inputs and outputs.
module sub_a ( in, out );
input in;
output out;
endmodule
module sub_b ( in, out );
input in;
output out;
endmodule
module toplevel;
wire one;
wire two;
sub_a sub_a_instance ( .in(one), .out(two) );
sub_b sub_b_instance ( .in(two), .out(one) );
endmodule
My interpretation of ur code sub_a input is wired to sub_b output. Am I right?
Yup, it just wires the inputs of each to outputs of the other. Of course the names are not exactly well-chosen. I just wanted to demonstrate the concept.
- Warren
Thanks you've cleared it up a lot. I have another problem. I'm trying to write a code for a chip that has 3 modules and the output of those three modules are connected to an AND gate. How do I go about doing that??
wire sub_1_output;
wire sub_2_output;
wire sub_3_output;
wire and_output;
and and_gate (and_output, sub_1_output, sub_2_output, sub_3_output);
- Warren
now that i have a one bit ALU, how would I link 4 of them together for a 4bit ALU? same method?
yep, just be careful not to mix up the carry signals...
  • · Replies 28 ·
