How Does Erasing Computer Memory Affect Entropy?
  • Thread starter Thread starter jlmac2001
    Entropy
The discussion revolves around the relationship between computer memory erasure and entropy, exploring how the physical states of memory relate to thermodynamic principles. Participants are examining the implications of erasing one gigabyte of memory and the associated entropy changes and heat generation.
  • Participants are attempting to define entropy in the context of computer memory and its erasure. Questions arise about the minimum entropy created during this process and the significance of the heat generated when this entropy is released into the environment.
The discussion is active, with participants sharing various definitions of entropy and its implications. Some suggest that the thermodynamic definition is relevant, while others question the necessity of more complex equations. There is a mix of interpretations regarding the relationship between information, entropy, and energy transfer.
Some participants express uncertainty about the definitions and equations applicable to the problem, indicating a need for clarity on the assumptions being made. The urgency of the homework deadline is also noted, which may influence the depth of exploration in the discussion.
jlmac2001
I don't get want a computer has to do with entropy. Can someone explain this question?
A bit of computer memory is some physical object that can be in two different states, often interpreted as 0 to 1. A byte is eight bits, a kilobyte is 1024 (=2^10) bytes, a megabyte is 1024 kilobyes and a gigabyte is 1024 megabytes.
A) Suppose that your computer erases or overwrites one gigabyte of memory, keeping no record of the information that was stored. Explain why this process must create a certain minimum amount of entropy and calculate how much.
B) If this entropy is dumped into an environment at room temperature, how much heat must come along with it? Is this amount of heat significant?
someone please reply please
I really need help with this. It's due tomorrow. Help please!
Essentially, all of the energy used by a computer to complete its tasks is released into the environment as heat/entropy.
It would help if you were to write out the specific definition of "entropy" you are using. (I know several different ones that apply to different situations.)
A good book that uses the computer to explain entropy is Theory of Everything by Stephen Hawking.
Your library might have it, so it's worth a shot.
Its fairly short, and informational, so it's worth reading it all. If you're lazy, you can find it in the last half somewhere.
Hmm...this indeed appears to be quite an interesting question. (I am currently studying Thermal Physics!)
I think here we are meant to take the thermodynamic definition of entropy. More specifically, I think we are dealing with the equation S = k*ln(W), where S is entropy, W is multiplicity (Number of microstates for a particular macrostate over the total number of microstates) and k is Boltzmann's constant.
The trick here I think comes in calculating W. The total number of microstates is (I think):
(2^8)*(2^10)*(2^10)*(2^10) = 2^38. However, I am also not quite sure how to explain why there has to be a minimum amount.
Regards,
The Keck
The point is that information cannot be destroyed, according to the deterministic and time symmetric laws of physics. Hence, when you instruct the computer to delete a gigabyte of information from its memory, each bit of that information must actually be transferred into some other form (typically heat, ie. random thermal motion).
Similarly, a binary logic gate with two inputs and only one output must create a bit of entropy for each cycle, so you can find papers that calculate the amount of heat that a particular CPU would produce if had its maximum theoretical energy efficiency.
So essentially what you are saying is that jlmac2001's questions A & B can not be calculated using the formula I stated in my previous post [S = k*ln(W)], but will have to involve other more complicated ones?
If that is so, it seems to me that we are reading too deeply into the question. I think this question can be solved without having to discuss things is the time symmetric laws of physics.
Thanks for the quick reply!
Regards,
The Keck
Keck, note I actually did not say that any more complicated equations must be used; I merely explained in physical terms the reason why that particular one is relevant, since nobody else (except perhaps JR) had done so. You on the other hand advised jlmac to "plug and chug", rushing to put numbers into an equation you had found without knowing "..how to explain why.." it works. Such demonstrates only an ability to pattern-match the symbols in the question with the symbols in textbook equation lists.
cesiumfrog,
Sorry if I sounded like a computer, just churning numbers without thinking. The reason was because me and my friends had already discussed (Or at least try to understand) the physical aspects of the question.
What I believe is happening is that when the memory is erased, you reduce the 'disorder' in the data (Local entropy), but would increase the total entropy. So reducing the local entropy requires energy and this gives rise to increasing total entropy. (Can you argue that the process is irreversible and so entropy has to increase?)
However, I am not sure if the heat created is significant.
Thanks and sorry again!
Regards,
The Keck
  • · Replies 39 ·
  • · Replies 29 ·
