Question on cardinality of sequences.
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Cardinality Sequences
The discussion revolves around the existence of a class of sets A that is a subset of P(Q) with specific cardinality and intersection properties. Participants explore theoretical aspects of cardinality, particularly relating to the cardinality of the reals and the nature of finite intersections among sets.
  • One participant proposes a class A defined as A={P(A') | |A'|
  • Another participant questions whether constructing an explicit example is necessary, implying a more abstract approach might be valid.
  • Concerns are raised about proving |A|=c and the intersection properties without an explicit construction.
  • A participant argues that A, defined as a union of finite subsets Q_n of Q, leads to a countable union of countable sets, thus making A countable.
  • Hints are provided regarding the use of decimal expansions and the construction of real numbers from rational numbers, suggesting alternative approaches to the problem.
  • Another participant considers the implications of sequences agreeing infinitely often on the nature of the sets being discussed.
Participants express differing views on the necessity of explicit constructions versus abstract reasoning. There is no consensus on the validity of the proposed definitions or the cardinality of the sets involved, indicating ongoing debate and uncertainty.
Some participants note that the cardinality of the power set of Q is c, but this does not resolve the question of whether the defined class A can achieve the desired properties. The discussion includes various assumptions about the nature of sequences and their intersections, which remain unresolved.
i need to show that there exists a class of sets A which is a subset of P(Q) such that it satisfies:
1) |A|=c (c is the cardinality of the reals)
2) for every A1,A2 which are different their intersection is finite (or empty).
basically i think that i need to use something else iv'e proven: which for every a in R, let s(a) in Q^N is an increasing sequence which converges to a, then |{s(a)|a in R}|=c
i think that such a class could be: A={P(A')||A'|<alephnull} where A' is a subset of Q, A is the union of all P(A') where A' is Q.
im not sure if A's cardinality is c, but other than this example i don't see how to show it.
i think it's related to what i typed in the second paragraph, perhaps i need to find a subset to {s(a)|a in R} which is still uncountable, but i don't see how.
The question states 'show there exists', right? That suggests to me that the first thing you shuold do is forget about constructing one explicitly.
so how should i prove it?
i mean do i have to assume that A is a subset of P(Q) and then prove that |A|=c and for every 2 sets in A, their intersection is finite or empty.
then one way to do so is, bacause A is a subset of P(Q) then |A|<=c
but we also have c<=|A| cause |A|=c... well I am stuck.
i don't think i can prove it without showing explicitly.
IMPORTANT: I haven't proved this myself, so do what you will with this advice.
ARGUMENT: how do you demonstrate that there are transcendental numbers? Cardinality of real numbers=c. Cardinality of Algebraic numbers=/=c. Hence there are transcendental numbers.
ANALOGY: take the set of all possible As with the finite intersection property. Count them. Count those where |A|=/=c. Are they the same? I suspect the answer is no.
what i did so far is:
A is a subset of P(Q), so i defined A as the union of the sets {Q_n} where Q_n are finite subsets of Q, which have cardinality |Q_n|=n, i think that bacuase there are c sets in P(Q) A equals alephnull*c=c so its cardinality is c.
and we have that every two sets which are in A are either their intersection is finite or empty, is this good definition?
There are countalby many Q_n for each n. Thus A is a countable union of countable sets, hence countable.
the fact that |P(Q)|=c doesn't have anything effect.
There's a simple constructive solution. HINT: think about decimal expansions.
Incidentally, the "finite power set" of an infinite set is the same cardinality as that set:
[tex] |S| = | \{ \, A \subseteq S \, | \, |A| < |\mathbb{N}| \, \} |[/tex]
my mistake, perhaps this appraoch will do:
iv'e defined Q_n to be finite subsets of Q, and A={Q_n|Q_n subset of Q} such that |Q_k|=k for every k nonnegative integer.
|A|=|UQ_n|=c
Q_n a subset of Q
and every two elements of A their intersection is finite or empty.
will that be enough?
In what way is that different from what you just did? Why is A uncountable? It is a countable union of countable sets.
To add to my hint, think about decimal expansions of all real numbers. And think about how R is constructed as the completion of Q.
Second this but note that there are several ways to construct R from Q. Since AKG uses the phrase "completion of Q", I assume he means defining R as equivalence classes of the set of Cauchy sequences of rational numbers.
One could also use the definition in terms of equivalence classes of the set of non-decreasing sequences of rational numbers with upper bound but not the definition as Dedeking Cuts.
the decimal expansion of all real numbers is infinite, but the decimal expansion of Q can also be finite.
perhaps i can construct A to be a family of sets of the finite decimal expansions of a particular real number, for example pi would have the set {3,3.1,3.14,...} and so on.
but i don't see how the intersection of two different sets in A WOULD BE FINITE OR EMPTY.
Well, what happens if two of these sequences agree infinitely often?
then they are the same.
anyway, i saw the solution in class, i tried to do something similar beore i handed the assignment, i hope i did well.
11K
  • · Replies 18 ·
