Can Elastic Collisions Be Solved Quickly with Minimal Steps?
  • Thread starter Thread starter rachelx46
The discussion revolves around an elastic collision problem involving two objects of equal mass, where one object is initially at rest. The original poster attempts to prove that the objects separate at a 90-degree angle after a glancing collision, referencing conservation of momentum and kinetic energy principles.
  • Participants discuss the relationship between the velocities before and after the collision, referencing conservation laws. The original poster presents a simplified equation derived from kinetic energy conservation and questions its validity. Others suggest the necessity of incorporating momentum conservation into the discussion.
The conversation is ongoing, with participants exploring the implications of the conservation of momentum in relation to the original poster's approach. Some guidance has been offered regarding the conditions necessary for the proof, but no consensus has been reached yet.
Participants are working under the assumption that the masses of the colliding objects are equal, which is central to the discussion. There is also a mention of the typical complexity of proving such a result, contrasting with the proposed simpler method.
rachelx46
so apparently, this problem usually would require, many hours, and quite a few pages to write a proof for this, but today, i was shown a way to solve it in only a few mintues with only a few steps...
an object of mass m collides elastically with a second object of equal mass initially at rest. If the collision is a glancing collision, prove they separate at 90 degrees.
where m1 = mass of object 1, m2 =mass of object 2, v = velocity of m1, x = velocity after collision of object 1, y = velocity of object after collision.
http://img159.imageshack.us/img159/6387/pyhsag3.png
http://img90.imageshack.us/img90/2593/phys2ul7.png
so then
1/2(m1)v² = 1/2(m1)x² + 1/2(m2)y²
cancel out and simplify
v² = x² + y²
would that be completely valid?
rachelx46 said:
so apparently, this problem usually would require, many hours, and quite a few pages to write a proof for this, but today, i was shown a way to solve it in only a few mintues with only a few steps...an object of mass m collides elastically with a second object of equal mass initially at rest. If the collision is a glancing collision, prove they separate at 90 degrees.
so then
v² = x² + y²
Almost. You have to add the condition that [itex]\vec v = \vec x + \vec y[/itex], which is a consequence of conservation of momentum. Since this is a triangle and v² = x² + y², as you have shown, then the angle between [itex]\vec x \text{ and } \vec y[/itex] must be 90 degrees.
This is a very useful thing to know for pool players, who use this principle to determine where the cue ball will go.
AM
AM
Consrvation of momentum states that:
[tex]m_1\vec v=m_1\vec x + m_2\vec y[/tex]
So why is that your condition is true?
Because we are given that m1= m2?
Oh my bad... I am sorry, I missed that.
  • · Replies 22 ·
  • · Replies 16 ·
