Proving the Distributional Sense of x*Pv(1/x) = 1: An Analysis
  • Thread starter Thread starter Tsunami
    Principle Value
The discussion revolves around proving the distributional identity x * Pv(1/x) = 1, focusing on the properties of distributions and their interactions with test functions.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore how to express x * Pv(1/x) as a distribution and its implications for test functions. Questions arise regarding the treatment of test functions and distributions, as well as the validity of certain steps in the reasoning.
Some participants have provided insights into the nature of distributions and their multiplication, noting that x can be treated as both a function and a distribution. There is an acknowledgment of the need to clarify the roles of test functions in this context.
There is a mention of the limitations in multiplying distributions generally, with specific focus on the unique case of x being both a function and a distribution. The original poster expresses uncertainty about the simplifications made in their reasoning.
Tsunami
Show that, in a distributional sense,
x* Pv(1/x) = 1
The function 1/x cannot be integrated locally in the origin. Nevertheless,
int(1/x, x=-1..1) =0, and thus convergent.
Therefore, one defines the (non-regular) distribution Pv(1/x), as follows:
<Pv(1/x), phi(x)> = Pv*int(phi(x)/x, x=-infinity..infinity)
which is defined to be equal to:
limit( eps->0) ( int( phi(x)/x,x=-infinity..-eps) + int( phi(x)/x, x=eps..infinity) )
My problem is that I don't really understand how I can write x*Pv(1/x) as a distribution. My attempt at a solution is as follows::
<x*Pv(1/x), phi(x)> = limit(eps->0) (int( phi(x)/x*x,x=-infinity..-eps) = int( phi(x)/x*x, x=eps..infinity)
If this step is allowed, then of course, this integration is equal to :
int(phi(x),x=-infinity..infinity) = 1 , because this is a distribution. But surely, it can't be as simple as that!
What you need to show is that the distribution
[tex]x \mathcal{P} \frac{1}{x}[/tex]
is the unity distribution. That is, you can multiply this distribution with another distribution without changing it. Alternatively you can show that the effect of using this distribution on a test function [tex]\psi[/tex] is the same as using the distribuition 1 on a test function.
Since [tex]\left< 1, \psi \right> = \int_{-\infty}^{\infty} dx \psi(x)[/tex]
and this is exactly what you have shown.
I think your last sentence is a little off though. Your "phi" is not a distribution, but a test function.
Remember that distributions are defined by the effect they have on test functions. So they take test functions (from some pre-defined function space) and produces a number.
There is not a general way of multiplying distributions. The only reason you can do it here is because x is not only a distribution, but is also a function. So what you need to do is apply P(1/x) to the function [itex]x\phi(x)[/itex].
Hey Status,
of course! That's great, I didn't realize you were allowed to treat simple functions as distributions/test functions interchangably. That is, I'd seen the property, but not what it was useful for.
Jezuz,
indeed, when aforementioned trick is allowed, it comes down to something as simple as that.
13K
  • · Replies 54 ·
18K
