Variation of velocity against distance, in an electric field
In summary, the conversation discusses the problem of sketching a graph of velocity against distance in an electric field, with the second part focusing on the graph when the electric field opposes the motion of an electron. The reasoning behind the graph being a straight line is explained, along with the relationship between the slope of the line and the direction of the force. The conversation also delves into the graph of velocity against time, with a comparison to the graph of position against time. Ultimately, the graph of velocity against distance would show a decelerating trend due to the opposing force of the electric field.
fffff
53
Right, the problem is of course to sketch a graph of velocity against distance in an electric field.
the second part, drawing the grapgh with an electric field opposing the motion of the electron.
Right, assume we have an electron. We know that the electrical field strengh/intensity would be uniform.
So we know that Electric field strength=force/charge. Since the electric field strength is constant, an electron will experience constant force throught the electric field.
So since, f=ma, the acceleration is constant.
So the graph of velocity against distance will be a straight line.
Please explain to me whether my reasoning is correct.
Now, the second part.
The electrical field lines are opposing the motion of the electron.
The electron will experience a constant opposing force. But it takes time for these two forces to balance. (the motion of the electron) against the opposing force because of the electric field.
So now the graph should look similar to a terminal velocity graph or underoot x graph.
You are correct in saying that the constant field (regardless of direction) will give you a constant force, and therefore a constant acceleration. So the kinematic equation for the velocity is
V = Vo + a t
So a plot of velocity versus time will be a straight line as you say. What can you say about the slope of the line versus whether the force is aiding the motion or opposing the motion?
Since the electric field lines are opposing the motion of the electron, the force would be resisting it.
So the acceleration would decrease until becoming constant.
The graph would be similar like the terminal velocity graph
No, I don't think that's correct. Consider the analogy of a ball in a gravitational field. If you're standing at the edge of a cliff (in a vacuum) and throw the ball straight down at some Vo, then its velocity keeps increasing as it falls down. If you instead throw the ball up with Vo, then what happens?
Ok, the velocity would decrease until becoming zero at maximum height,
Similarly, in an electric field, instead of gravational force opposing the object. The force from the electric field is opposing it. So the graph would be
So the graph would look like this.
Pic of graph is in the attachment
If you plot position versus time, you should get a parabola. If you plot velocity versus time, you should get a straight line like in the equation for V that I posted earlier.
so what would the graph look like :(
I mean a graph of velocity against distance should be ??
The velocity would take some time to accelerate, since there is a resisting force the gradient of acceleration should be decreasing. That means velocity is decreasing not constantly against distance because the acceleration is decreasing.
this is the problem, the electron is released from A. The electric field lines are opposing the motion of the electron. Thus the object should be decelerating
A !----<----! B
http://enpub.fulton.asu.edu/nsfreu/Raymond/Image188.gif
the graph would look like that i mean.
What is the relationship between velocity and distance in an electric field?
In an electric field, the velocity of a charged particle varies with the distance it travels. This relationship is known as the variation of velocity against distance.
How does the electric field affect the velocity of a charged particle?
The electric field exerts a force on a charged particle, causing it to accelerate or decelerate. This change in velocity is directly proportional to the strength of the electric field.
What is the significance of studying the variation of velocity against distance in an electric field?
Understanding this relationship is crucial in many areas of physics, such as in the design and operation of electric motors and generators. It also helps us understand the behavior of charged particles in complex electric fields, such as those found in plasma or in the Earth's ionosphere.
How does the variation of velocity against distance differ for positive and negative charges?
For a positive charge, the velocity decreases as it travels against the direction of the electric field, and increases as it travels in the same direction. For a negative charge, the opposite is true.
Is the variation of velocity against distance affected by other factors besides the electric field?
Yes, the mass and charge of the particle, as well as the presence of other forces such as gravity or magnetic fields, can also affect the variation of velocity against distance in an electric field.
