Is the Concept of 'Location' Defined as a Single Point in Mathematics?
  • Context: Undergrad
  • Thread starter Thread starter Eh
    Geometry
The concept of 'location' in mathematics is defined as a point with zero dimensions, represented by coordinates such as (x,y,z). In discussions about celestial bodies like Jupiter, the definition of location becomes complex, as Jupiter can be represented by multiple points depending on the scale of the model used. While the center of Jupiter can be defined as a single point, the planet itself occupies a set of points in space. The mathematical interpretation of location can vary based on the model applied to represent non-mathematical entities like planets.
  • Understanding of mathematical concepts such as points and dimensions.
  • Familiarity with coordinate systems (e.g., Cartesian coordinates).
  • Basic knowledge of mathematical modeling techniques.
  • Awareness of the differences between mathematical and physical entities.
  • Explore mathematical modeling of celestial bodies using tools like MATLAB or Mathematica.
  • Study the implications of scale in mathematical representations of physical objects.
  • Research the concept of dimensionality in mathematics and its applications.
  • Investigate the differences between discrete and continuous representations in mathematics.
Mathematicians, educators, students in mathematics or physics, and anyone interested in the intersection of mathematical theory and physical representations of objects.
Eh
A precise location is defined as a point with zero dimensions. So we can easily tell you where the location of something is, say at (x,y,z) from the starting point. But let's say you had a map of the solar system, and used a scale that is too small. The planet Jupiter would now be found at several locations at once.
Anyway, the question is: does the word "location" only have one mathematical definition, being an exact point? In the case of Jupiter, are there there several locations where you will find the gas giant, or can you define a single location as a collection of points?
Mathematics news on Phys.org
Most people would be happy with the definition that the center of the planet exists at a single point in space, while the planet itself exists at a set of points.
- Warren
"Point" is, as you say, a mathematical concept. "Jupiter" is NOT a mathematical concept. You could, of course, set up a mathematical model that more or less accurately modeled Jupiter. Whether you could assign a single point to Jupiter would depend upon your mathematical model.
  • · Replies 64 ·
  • · Replies 31 ·
