Register to reply
Determine acceleration/tension of masses
by LCc
Tags: determine, masses
Share this thread:
LCc
#1
Jan17-07, 06:13 PM
P: 149
A mass, [tex]m_1[/tex]=5 kg, resting on a frictionless horizontal table is connected to a cable that passes over a pulley and then is fastened to a hanging mass, [tex]m_2[/tex]=10 kg. Find the acceleration of each mass and the tension in the cable.
2. Relevant equations
3. The attempt at a solution
For mass 1:
Sum of x = F=[tex]m_1[/tex]a where F= Forward Force
Sum of y= n - [tex]m_1[/tex]g=0 where g=9.8 m/s
How can I determine the acceleration using the data for mass 1?
For mass 2:
Sum of Y = [tex]T_2[/tex]-[tex]m_2[/tex]g where T= tension
Hence, [tex]T_2[/tex]= 10 kg(9.8+a)
Then, what do I do?
Phys.Org News Partner Science news on Phys.org
Pilot sites in energy from coffee waste show good results
Startups offer banking for smartphone users
Factor in naked mole rat's cells enhances protein integrity
mjsd
#2
Jan17-07, 06:28 PM
HW Helper
mjsd's Avatar
P: 860
ok let's hope I have got the picture correct. I have got things wrong twice already this week when answering questions......
firstly, no friction... greatly simplify the problem. so only one force on mass 1 that would actually cause movement/acceleration
assuming the cable is massless/non-stretch-able etc... also a perfect pulley of course... then you must have
Tension on m1 equal Tension caused by m2.. so only one T.
T is of course equal to something times g (what is that something eh?)
ok.. forgot to read the question.. ok you want to answer acceleration for each mass
for m2 ... easy
for m1 ... use relation from the only one T you have
for T ... once you know acceleration on m2 or m1... easy
LCc
#3
Jan17-07, 06:40 PM
P: 149
Quote Quote by mjsd View Post
for m2 ... easy
are my expressions correct?
mjsd
#4
Jan17-07, 07:18 PM
HW Helper
mjsd's Avatar
P: 860
If I have got your picture correct... then your expression
T_2 = 10(9.8+a)
is not quite right.
mjsd
#5
Jan17-07, 07:20 PM
HW Helper
mjsd's Avatar
P: 860
my picture (for cross-checking): gravity pulls m2, m2 pulls T, T pulls m1 and m1 accelerate....that's it
turdferguson
#6
Jan17-07, 07:21 PM
P: 312
Acceleration is always the same for both blocks, and in most cases tension will also be the same (the only time tensions do not equal eachother is when the pulley is massive and its rotation is taken into account)
Because there is no friction, the forces in the y for block 1 are of no concern. For your second equation, however, the best choice for positive is the direction of acceleration. Once the signs are straightened out, plug tension into the first equation and solve for a
LCc
#7
Jan17-07, 07:37 PM
P: 149
I'm sorry I cannot put up the diagram, but I think you have the wrong picture. It's not the atwood machine, so the tension along the cord is not the same, since we are not dealing with one system where gravity is acting on it. Mass one moves due to the forward force, and mass two due to the gravitational force, and the normal force (which is the tension along the cord).
PhanthomJay
#8
Jan17-07, 08:26 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,040
Quote Quote by turdferguson View Post
Quote Quote by LCc View Post
The way the problem is worded, one would guess that the forward force you refer to is the tension force in the cable. Which, as pointed out, is the same as the tension force on the hanging mass. And the magnitude of the accelerations of both blocks must be the same. Solve the 2 applicable equations using free body diagrams and Newton 2.
turdferguson
#9
Jan17-07, 08:27 PM
P: 312
The forward force IS the tension in the rope. Especially with no friction, the rope is the only thing accelerating m1
One way to think of it is that the 2 tensions are internal forces. Therefore, they must cancel out because nothing inside the system is moving (remember, the pulley isnt rotating). In this respect, the problem is like an atwood machine because the entire thing can be called a system which gravity acts on. If anything, its a simplified atwood machine because only one force accelerates m1
mjsd
#10
Jan17-07, 08:32 PM
HW Helper
mjsd's Avatar
P: 860
Firstly, I didn't see it as a atwood machine.
The total forward force for m1 can only come from the tension T, since there is no friction. For m2, there are two forces acting, T and gravity. My claim is that the two T's are the same because of all those assumptions I mentioned, non-stretchable, massless string, frictionles + massless pulley.etc. (think about it, you will notice that the two's T in your diagram actually points in towards/away from each other, and if they are not the same, there will be a net force, and something will happen to the string!)
Now total force on m1 is F1=m1 a... and you want to find this a.
Register to reply
Related Discussions
Two Hanging Masses (TENSION) Introductory Physics Homework 5
Three masses on a frictionless surface. Find Acceleration and tension. Introductory Physics Homework 1
Help Finding the Tension between 2 Masses Introductory Physics Homework 1
Determine mass and acceleration... Introductory Physics Homework 1
Acceleration of masses Introductory Physics Homework 4
