Potential Energy of coffee mug Problem
The discussion revolves around calculating the potential energy of a coffee mug situated at different heights. The original poster presents a problem involving a mug's potential energy with respect to both the floor and a countertop, leading to questions about the correct height difference to use in the calculations.
  • Participants discuss the formula for potential energy and the importance of the reference point for height. The original poster attempts to apply the same method used for the first part of the problem to the second part but receives feedback suggesting a reconsideration of the height difference. There are questions about why the height difference is necessary and how it affects the potential energy calculation.
Participants are actively engaging with the problem, exploring different interpretations of height differences and potential energy calculations. Some guidance has been offered regarding the reference point for potential energy, but there is no explicit consensus on the correct answer, as the original poster continues to express uncertainty about their calculations.
The discussion includes references to an online homework system that does not provide feedback on incorrect answers, contributing to the original poster's frustration and confusion about the problem.
Cole07
1. A 0.342- kg coffee mug rests on a table top 0.67 m above the floor. What is the potential energy of the mug with respect to the floor?
Answer: 2.25J
B. What is its potential energy with respect to a counter top 1.1 m above the floor?
Answer:?
P.E.=mgh
i thought that i would do the problem exactly the same as i did the first.
(0.342)(9.8)(1.1)= P.E. because for the first problem i used the same thing except for 1.1 instead i used 0.67 for the first problem. The answer that i get for the second problem is 3.68676J but I'm told this is not right.
any help would be appreciated.
The distance you should use is not 1.1. Think about the situation. What is the difference in height between the coffeed mug and the counter?
you mean 0.43?
That's correct
so i do the same thing only it would be (0.342)(9.8)(0.43)which is 1.441188J ?
-Why do you find the difference?
Because you want the potential energy of the mug with resoect to the counter. Recall that the potential energy is defined as [itex]V=mg\Delta h[/itex] where [itex]\Delta h[/itex] is the change in height. For the first part [itex]\Delta h=0.67-0[/itex] since we define the ground to be the origin of the coordinate system. So, for the second part, [itex]\Delta h=0.67-1.1[/itex] with regard to the coordinate origin. Note that the change in height should strictly be -0.43, since, of course, the coffee mug has less potential energy on the table than it would have on the counter. You can argue this by taking the counter as the origin (since this is the point we want to calculate the potential with respect to) and thus the coffee cup is -0.43 (i.e. 0.43 metres down)
Oh ok i understand this , but the answer i got still doesn't seem to work?
What do you mean "doesn't work?" Do you have the solution to the problem?
not the soulution its online homework it tells me I'm wrong but it does not say why or give any help and i hate it but I'm not very good at physics as you can probably tell.
Hmm, well I'm not sure I can help much more! The answer is either 1.44 (or more correctly -1.44). If neither of these work, then the answer (on the online system) is wrong!
well i didn't try negative at first it is right though could you possibly explain why?
The potential energy is measured with respect to some reference point, and we should make this point the origin of our coordinates. For 1. the origin is the ground, with positive direction upwards, and so h=0.67. For 2. the origin is the counter-top, also with positive direction upwards, and so the h=-0.43, since the coffee cup is below the counter.
:approve: oh i see thank you very much for all of your help i really appreciate it.
well, understand that sometimes the way we use energy is based on conventions that make it easily usable in some generalized formulas. So in order for this to work for the basic formula E(initial)=E(final) it needs to be negative. Say it starts by going up with some initial kinetic energy. To determine its speed at the countertop, you would need to say E(initial)=K(initial)+U(initial)<<which is negative. if you set this equal to energy at the top then it will work out. Note that the important thing here is keeping a consistent refrence frame. If we had chosen the table to be the refrence frame, your potential energy would start at zero and end up at a positive number--either way it works. Did that make any sense?
sorry--too late.
yes thank you
  • · Replies 23 ·
